Login Error
Close
4 Reasons to Build a Garage Loft
by DoItYourself Staff
If you need extra storage space in your garage, it is a good idea to build a garage loft. Garage lofts can be built in a wide range of styles to your budget. Here are some of the reasons to build one.
Reason 1 - Storage Space
The main reason that people build a garage loft is for extra storage. If you have items that you need to keep but don't use on a regular basis, such as holiday decorations, then having loft space can be an ideal place to put them.
Reason 2 - Office Space
If you have room in your garage, then loft space can be utilised for office or planning space. This is especially useful if you use your garage for projects such as car building or woodwork.
Reason 3 - Guest Accommodation
The loft of a large garage can be completely converted into a small apartment or guest accommodation. This will add value to your property and also provide you with an extra bedroom for whatever purpose you need it.
Reason 4 - Cost
Building a garage loft will add value to your property. It is also an inexpensive way of creating much needed space without having to move home. It can be done on a small budget, often without the need to hire in external contractors.
 forum activity
