4 Reasons to Build Your Own Garage Workbench
If your garage doubles as a workshop, a garage workbench is a practical investment that will add great versatility. A workbench will provide a work surface while providing spaces to organize tools and other materials. Pre-made workbenches can be expensive. Building one yourself is a great DIY project and offers many benefits.
1 – Size is Everything
Buying a workbench may not be suitable for your size of garage or the space you have available. Therefore, building your own allows you to customize its size and placement within the space allowed.
2 – Cost Effective Solution
Building your own garage workbench is also very cost effective. You can opt to save money by using recycled or reclaimed equipment and materials. A homemade workbench affords you the luxury of creating your own design and system of storage and surface area.
3 – Tool Storage
Creating your own tools storage is also cheaper than buying a ready made system and it may suit you better to design something that you find easy to use. Large appliances can be stored on a shelf underneath while smaller tools can be hung from pin boards above the workbench. Your tools will easy to locate and easy to put away when you're finished working.
4 – Personalized Set up
Building your personalized setup in your garage also allows you to work your system into some of the more small spaces or corners that garages have. If your garage is split into sections for laundry or freezers and such, you can design your bench to get the best from it.
