4 Reasons to Use Vinyl Coated Chain Link Fence
A vinyl coated chain link fence is one of the cheapest and most secure ways to guard your property. The sizes available for the material range from 42 inches to 72 inches. There are also a wide range of colors to choose from such as white, brown, black and green. Many people use the material in guarding their property because it has less visibility. It can also be used for ornamental purposes for areas of the yard that has higher visibility than the other parts. Since it was first introduced, the fence gets the highest demand from consumers because of its low cost.
Easy Availability
A lot of companies are manufacturing vinyl coated chain link fence that are suited for your particular needs. Hence you can use it on more areas than any other material such as around the tennis court, the swimming pool and gardens. It is also ideal to be used on stadiums. You can easily order to material from the comforts of your own home or office by calling an outlet and the fence will be delivered to you the soonest time possible. When you order the fence this way, make sure that you purchase an extra length than what is needed for the stretch.
More Options
Vinyl coated chain link fence generally can be purchased in two kinds. These are the bonded vinyl fence and the extruded vinyl fence. Extruded vinyl is cheaper than the bonded one, so if you are short on the budget, you can opt for it. The vinyl on an extruded fence though can be peeled off much like you do with a banana once you cut it with a knife although it can be quite hard. You can have more savings by buying in quantity. The vinyl fence comes in rolls which usually measure 50 feet to a roll. The price however, is per feet and is usually from 5 to 6 dollars.
More Value and Security for your Property
Installing a vinyl coated chain link fence will increase the value of your property and add to your security. It can be a great addition to your swimming pool area or around the kennel for your dog. It can be used to protect your garden from stray animals that may destroy the plants in it, which may be of value to you.
Better to Use
Vinyl coated chain link fence is a better choice for use on residential and commercial areas and is the best on for establishments such as golf courses and daycare centers. The most common color used is black, which is also the most trendy. The vinyl fence can be bought with a long term warranty which is usually from 10 to 12 years for a residential vinyl fence and from 13 to 15 years for commercial application. The warranty given may also depend on the company that manufactured it. All of the vinyl coated fences that are sold on the market have been galvanized with zinc.
When purchasing the fencing material, do not buy the first one you come across. Instead make a careful research on each manufacturer and choose from among the best ones that you have considered for quality, cost and warranty period.
