4 Recipe for Homemade Aluminum Cleaning Solutions
Aluminum is a type of non-ferrous metal that has a low density. It is also corrosion-resistant making it an ideal material for many common items like pots and pans. However, aluminum can also tarnish. There are some ways you can bring back the shine of your aluminum items without the use of commercially-produced products. Below are some great homemade recipes you can use to clean your aluminum items.
1. Discolored Aluminum
One of the most common problems with products made from aluminum is that it loses its color. You can use plain vinegar or cream of tartar to restore the color of the aluminum. All you need is a tablespoon of the vinegar for every quart of water. Heat this solution in the aluminum pan until discoloration disappears. You can also use 2 teaspoons of cream of tartar for every quart of water. Using the same method of heating until discoloration is no longer apparent.
2. Aluminum Door Frames and Windows
Sometimes cleaning aluminum windows and door frames with soap and water is not enough. Using plain soap and water can not bring back the original luster of the aluminum. However, there is a simple homemade recipe that you can do to bring the shine back into the aluminum.
All you need is a few slices of lemon, water, and vinegar. These 3 common household items are all you need to create a cleaning solution that can also bring the shine back into your window and door frames. To create this recipe, mix 4 cups of water and 1 cup of vinegar in a container or spray bottle. Rub the lemon slices directly onto the aluminum surface and then rinse it off using the water and vinegar solution.
3. Aluminum Pots and Pans
You do not need to scrub your aluminum pots and pans to death to keep it clean and shiny. There is a homemade recipe that you can create to clean your pots and maintain their luster. You need cream of tartar and vinegar or lemon juice for this homemade recipe.
All you need is to fill up your pan or pot with water making sure that you use about 2 tablespoons of cream of tartar for every quart of water. Add ½ cup of lemon juice or vinegar into the pot. Allow this solution to reach rolling boil. Let it boil for 10 more minutes before you remove the solution from the pot. Let the pot cool. Once the pan or pot is cool, wash it and allow it to dry. This will effectively clean your aluminum pots and pans and at the same time restore their shine.
4. Other Aluminum Items
Aside from using vinegar, cream of tartar or lemon as ingredients to your homemade aluminum cleaning solutions, you can also use tomatoes and rhubarb. These 2 uncommon ingredients can be used to clean smaller items made from aluminum. All you need is to fill a container with water, place the aluminum item and add some stalks of rhubarb or tomatoes in the container. Boil everything together. After boiling the solution, turn the heat off and let the liquid mixture cool. You can now wipe the item dry with a cloth.
