Login Error
Close
4 Safety Tips to Remember when Using a Pellet Stove
by DoItYourself Staff
Installing a pellet stove in your home has become a very popular way to heat. Many people are turning to pellet stoves as a viable alternative to gas or wood heat. However, when using this type of stove, there are a few safety tips that you will want to keep in mind. Here are some of the most important things are members in regards to safety when using a pellet stove.
1. Burn Approved Substances
Pellet stoves can burn a mixture of different pellets and even corn. As a result of this, many people think that they can burn anything in the pellet stove. However, you will want to avoid burning anything that is not on the approved list of burnable substances. Only burn the proper pellets for your pellet stove. Burning anything else could result in the combustion of something that is dangerous or even explosive. Therefore, it is best to stick to the basics when choosing things to burn in your stove.
2. Choose the Right Place
When you are installing a pellet stove, you will want to make sure that you choose a suitable location for it to sit. You cannot simply place a pellet stove anywhere in the house. Once you get it in place, you will not be able to pick it up and move it as if it was a piece of furniture. Therefore, you should do some planning on the front end to try and find the best location. Make sure to put the pellet stove in a place that will not be near any furniture or combustible objects. Keep it away from the drapes or anything else that could get near the pellet stove and catch on fire.
3. Watch for Carbon Monoxide
Burning a pellet stove will put off carbon monoxide. A properly vented stove will not allow carbon monoxide to get out into the house. However, if there is a faulty vent installation, carbon monoxide could get into your home. Carbon monoxide is a very poisonous gas that can be deadly. In order to protect yourself, it is a good idea to install a carbon monoxide detector within 10 feet of the pellet stove. Therefore, you will know immediately if carbon monoxide gets out into your living quarters. Carbon monoxide needs to be vented properly in order to prevent serious health concerns. Invest a few dollars and a carbon monoxide detector and it can possibly save your life and the lives of your family members.
4. Read the Manual
Regardless of how many pellet stoves you have used in the past or how well the installer explained the process to you, you still need to sit down and read the instruction manual. Each pellet stove will come with a specific set of instructions. Make sure that you take your time and read them to avoid any potential problems in the future. This will help you know exactly how to use your stove in the safest manner possible.
 forum activity
