4 Sauna Floor Care Tips
You can do a number of things to ensure your sauna floor lasts for a very long time. If you have been using your sauna for a while without paying particular attention to the floor, you may find that the wood starts to peel or that grouted floors start to loose the caulking edge. These issues can lead to serious problems with the floor, such as loose planks and free tiles. Keeping the floor clean and dry is one of the most important things you can do to keep the sauna working well.
Avoid Leaving Water on the Floor
In older saunas, there used to be a hole in the floor through which moisture could easily drain. Modern saunas, particularly personal saunas or portable ones, do not have this facility, so water that does not evaporate stays on the sauna floor. This water can cause a serious problem if you are trying to maintain the sauna floor. Make sure you don't place too much water onto the heater at one time, as this can cause large pools of water to drain onto the floor. Never clean the sauna by spraying it with a pressure washer. All of these actions could lead to the floor of your sauna suffering water damage.
Clean the Floor after Use
Every time you use the sauna, take a few minutes to clean up the floor afterward. Pay attention to the area around the feet of the sauna benches, as dirt can gather here. Scrub your floor regularly, at least once a week if you use it often. Don't leave water on the floor but mop it up immediately. Also don't use water-based cleaners, bleach or powerful chemicals, particularly as they may evaporate during sauna use and enter the air.
Treat the Floor Annually
If you use your sauna often, it is also a good idea to cover it with a waterproof varnish, which will help keep the water off your sauna floor. It will also give your sauna floor a nice shine. Use a paintbrush to apply the varnish; never spray it on, as this can trap water behind the varnish.
Practice Good Maintenance
As well as an annual varnish treatment, you should also spot-check the sauna after use for cracks or damage. Tiling around the entrance to the sauna can also develop water damage, so you should check this first for signs that the grout is coming away from the tiles. Restore loose grout. You should then move onto the wood on the sauna floor. Look for signs that the wood is peeling, or for cracks in the timbers as they split due to moisture. Replace damaged wood as soon as possible.
