Login Error
Close
4 Steps for Rear Sway Bar Replacement
by DoItYourself Staff
what you'll need
  • Socket set
  • Open ended wrench set
  • WD-40 or similar lubricant
  • Replacement sway bar and brackets
  • Creeper
  • Wheel chocks
  • Safety glasses
The rear sway bar is a component of the suspension that some vehicles have that helps stabilize the vehicle when making turns or hard curves. The sway bar connects from the sway bar bushing on the suspension of one rear wheel to the other traveling across the rear of the underside of the vehicle, usually secured to the chassis with a variety of brackets or bolts, depending on the make and model. Occasionally, due to excessive wear or undercarriage damage, the sway bar can be damaged or broken, requiring replacement. In this article you will find the basic steps needed to replace the sway bar.
Step 1 - Prepare the Vehicle
Position the vehicle so the area of the rear axle is as accessible as possible. Set the emergency brake, put the vehicle in gear, and chock the front wheels. Make sure that the vehicle is as stable and secure as possible. Put on your safety glasses and gather your tools. Get on the creeper and scoot under the vehicle with your tools. Locate the sway bar. This will be secured to the rear chassis and extend from the right to the left rear wheel suspension. Locate the brackets that secure the sway bar to the chassis, and the sway bar to the sway bar link. Identify the sway bar bushings that connect from the wheels to the sway bar. Spray any bolts with the lubricant and let it soak in for a little while to ease removal.
Step 2 - Remove the Sway Bar
First, disconnect the sway link from the sway bar on both sides of the vehicle. Disconnect the sway bar links on both sides. Using your sockets and/or wrenches, loosen and remove all the bolts connecting the bushings to the suspension. Loosen and remove bolts from the brackets (if present) securing the sway bar to the chassis. Disconnect the sway bar bushings. Remove the sway bar and bushings from underneath the car.
Step 3 - Replace New Sway Bar
Remove the sway bar bushings from the damaged sway bar and inspect for excessive wear or damage. Replace the bushings on the new sway bar as they were inserted to the original sway bar. Slide your new sway bar and bushings underneath the vehicle and gather up brackets (if applicable). Scoot back under the vehicle and reattach the sway bar links, then reattach the sway bar bushings in the same manner they were originally secured to stabilize the new sway bar. Reattach the sway bar the same way the old was attached to the chassis, and replace brackets if appropriate. Tighten all bolts down. Gather all your tools and materials and scoot out from underneath the vehicle. Remove the chocks from behind the front wheels.
Step 4 - Test Drive the Vehicle
Take the vehicle for a test drive to ensure it is working properly. If there are any concerns, park the vehicle, set the emergency brake, chock the wheels and inspect for any missing connections. Recheck that the connections are secure and tighten if necessary after a couple of weeks of driving.
 forum activity
