4 Things You Need to Know Before Buying Electric Garage Heaters
If you use your garage for more than just storing your car, electric garage heaters are an absolute necessity. After all, most garages are not as well insulated as the rest of the house. So if you spend a lot of time in your garage, it makes sense to ensure that you will be warm and cozy while you are there. Given below is a list of things that you need to keep in mind before your pick electric garage heaters for your home.
1. Type of Heater
There are basically two types of electric garage heaters—convection heaters and radiant heaters. Convection heaters have a heating element. When air passes over this heating element, it is heated, and as a result, it rises to the top. Meanwhile, the colder air comes down; the cooler is again passed over the heating element, thereby setting up a convection current. Convection heaters are very safe and noise free. Another variation of the convection heater is the forced air convection heater. This type of heater incorporates a fan that speeds up the airflow over the heating element, resulting in faster heating.
Radiant heaters are also popular as electric garage heaters. These heaters contain a heating element that radiates heat in the form of infrared rays. These rays pass through the surrounding air without heating it and instead heat the object that is in their line of sight.
The basic difference between these two types of heaters is that while you will be heating up your entire garage with convection electric garage heaters, you will only be focusing the heat upon yourself with radiant heaters. Radiant heaters are slightly more portable than convection heaters. They can also be placed anywhere, unlike convection heaters that work best when placed on the floor. Convection heaters are the most popular type of electric garage heaters.
2. Capacity
Most convection electric garage heaters can easily heat a garage of around 300 square feet. If your garage is slightly larger than this, you will need more than one heater or a heater with a slightly larger capacity. If you do not spend considerable time in the garage, you can use a radiant heater to keep yourself warm during work.
3. Availability of Power Outlets
Electric garage heaters should never be plugged into extension cords. They should always be directly plugged into wall power outlets. If your garage does not have sufficient power strips, you may have to get some installed.
4. Other Heating Options
The only downside to electric garage heaters is that they can make your electricity bills rise significantly, especially if you use them all the time. If you have a large garage that you use frequently, you may want to check out other heating options for your garage. If your house has piped natural gas or liquefied petroleum gas, then natural gas heaters or liquefied petroleum gas heaters can be an excellent option to electric garage heaters. Another option is a propane heater. Do ensure that your choice of garage heater does not contravene any local fire and safety laws.
