Login Error
Close
4 Tips for Choosing a Portable Spa Heater
by DoItYourself Staff
When you are buying a big ticket item such as a portable spa heater, you will want to make sure that you are buying the best heater for you. Here are a few tips to make sure that you get the most for your money.
Tip 1 - Ask About Warranty and Maintenance
Many people ask about the price right away when buying a bigger item like a spa heater but they forget to ask about other costs that may add on or take off of their overall investment and this is a big mistake. While some portable spa heaters are less expensive upfront, you don't want to be fooled by any maintenance that comes a long later. Always ask questions about how the spa heater will be cleaned or maintained as well as whether or not there will be added costs in the long run. On the flip side, you may also want to talk about warranties. Yes, you will have to pay more upfront for a warranty but in the long run this may save you the most money if you were to have a problem or need something fixed. Make sure to find out what is covered under the warranty as well as looking up the products history on line or asking around to see if there are common problems.
Tip 2 - Electric or Gas
While there are some brands that do carry a gas portable heater, you almost always will find them in electric. If this is not something you are looking for you may want to consider not going with a portable. However, the electric portable spa heater is the most popular and has many benefits to it. While gas is somewhat less expensive, an electric heater is much more reliable. Many of these electric heaters can also just be plugged into a regular outlet while others may need a GFCI protected circuit. You will have to talk to your village building department to find out or an electrician. You will want to consider this before you purchase the heater. Also, keep in mind that many portable heaters are about 110-volts.
Tip 3 - Size of the Spa
You will want to keep in mind the size of the spa when you are considering whether or not to get a portable spa heater. The bigger the spa, the more voltage you will want. The portable heaters only come up to about 110-volts as opposed to the 220-volts of a regular heater. So if you are going for a bigger spa you may want to consider a regular heater.
Tip 4 - Shop Around
The first thing you will want to do is to make a list of priorities as well as qualities of yourself and the spa. Size of the spa as well as the size of your wallet with both come into play. By shopping around after you know what you need, you will be able to narrow down your choices and make an educated decision.
 forum activity
