Login Error
Close
4 Tips for Choosing an Asbestos Testing Kit
by DoItYourself Staff
Asbestos is still found in older homes and buildings which make purchasing an asbestos testing kit important. Asbestos, if left unchecked, can cause many health issues. Removing asbestos is a huge job that is also expensive but has to be done. If you feel that your home has asbestos siding or insulation then you need to know. An asbestos test kit will be able to answer these questions for you but there are many on the market. The information that you will find in this article will be valuable in helping you choose which asbestos testing kit is right for you.
1 - Cost of the Kit
There are many people that say you cannot put a price tag on peace of mind or your safety but in these trying economic times this simply is not the case. You can find an asbestos testing kit for as little as $14.00 but they can also be found for prices well over $100.00 but price does not mean quality. Always set a budget when you go shopping for an asbestos testing kit to avoid paying too much for a product that may not work as well as you would like it to.
2 - Immediate Results Testing Kit
Getting ill from asbestos is not an overnight thing. If you want to know right away that your house is safe then an asbestos testing kit that gives results quickly is right up your alley. There are many different types of asbestos testing kits that give immediate results. One problem with an immediate testing kit is that you have to rely on yourself to do the test correctly. These tests are all-inclusive which means you have a sample pouch of some sort and a chemical agent. It is your job to scrape off a piece of the siding or the insulation and place it in the pouch. You add the chemical to the pouch and wait a few seconds. The result is then determined by your ability to read the instructions accurately. The importance is to make sure that the asbestos testing kit is completely sterile.
3 - Lab Result Kits
The main issue you will have with an immediate results asbestos testing kit is that they are not always that accurate. This inaccuracy can be attributed to many factors including the age of the kit you purchased. You do not have this issue with an asbestos testing kit that requires you to send a sample to a lab. You simply scrape away a sample of the siding or a few fibers of insulation and place it inside a sample pouch. You then take the sample pouch and send it off to the lab using the shipping pouch the kit provided.
4 - Contents
One thing you need to consider is what comes in the asbestos testing kit. Never buy a kit that has no expiration date on it let alone a kit that has you using household items. Only buy an asbestos testing kit that includes everything you need but also one that is fresh.
 forum activity
