Login Error
Close
4 Tips for Cleaning a Steam Shower Unit
by DoItYourself Staff
A steam shower unit heats up water to create vapor in the shower. The steam that is produced surrounds the person’s body and essentially does what a normal shower does. A steam shower unit has all of the benefits of a steam sauna and a typical shower. A shower steam unit is often added to a normal shower and can be turned on or off at the whim of the user. Every shower needs cleaning, regardless of whether it uses steam or a continuous flow of water. The article that follows will share some tips on how to properly clean a steam shower unit.
1. Calcium Remover
Calcium is often the culprit of a clogged shower head or steam nozzle. Hard water is fairly common, and once the water has evaporated, calcium deposits are left behind. The nozzle of a steam shower unit or shower head can easily become clogged with these deposits. You will be able to notice a white chalky substance around the metal that may resemble barnacles on a boat. A calcium remover should be used periodically even if there are no visible signs. Fill a small bowl with it and let the nozzle sit in it for several minutes before wiping it off and running the water for a few seconds.
2. Power Push
A steam shower unit that is installed to a normal shower has a unit on the outside of the casement. This can be under a sink, outside the home or in a cupboard. They all come equipped with the ability to completely flush the system. This is a routine maintenance to make sure the steam shower unit is working up to specs. You will need to go to the unit and open it up from the back. There will be a button to push or a valve to turn. It can say push or flush so you know it is the correct button. Consult the manual beforehand to know what you are looking for. Press the button and wait several minutes for it to run its course.
3. Tire Cleaner
Many shower stalls have metal to secure doors as well as shower heads and steam nozzles. These easily become covered with grime and dirt. You can clean the metal easily by using tire cleaner or polish. This also helps prevent further instances of dirt and grime from sticking to the material. Merely spray it on a rag and buff the metal. When you are finished, wipe it off with a fresh rag.
4. Mild Detergent
Soap scum and body oils and grease are very commonly found in showers. A steam shower unit does not prevent this from happening. Cleaning the shower area is a chore, but it has to be done every few weeks or you will wind up getting mildew. A simple mild detergent that is oil free is the key to cleaning the glass and the tile.
 forum activity
