Login Error
Close
4 Tips for Cleaning Marmoleum Flooring
by DoItYourself Staff
If your Marmoleum flooring has recently become dirty, you're probably wondering how to go about cleaning it. While cleaning  Marmoleum flooring requires a little bit more finesse than cleaning regular flooring, making your Marmoleum floor spotless can be a relatively simple task, particularly if undertaken with a helpful set of hints at your disposal. So if you're ready to say goodbye to your dirty Marmoleum floor, simply read on to learn everything you'll need to know.
Tip#1 - Make Sure the Floor is Free of Dust
Before you begin the cleaning process, you should vigorously vacuum or sweep your Marmoleum floor and make sure it has been completely purged of dust. Additionally, you may want to run a wax stripper across the floor. This will help ensure that the cleaning goes over smoothly. Any remaining dust is liable to cause problems once the cleaning process is underway, so make sure to give your floor a thorough dusting before proceeding any further.
Tip #2 - Vinegar Cleaning
Vinegar can be a very effective tool in keeping your Marmoleum floor clean, as the chemicals found in many commercial cleaning products are often too harsh for this type of flooring. When cleaning your floor with vinegar, make sure to dilute it with water and use it in conjunction with a clean cotton washcloth. Certain brands of vinegar can be somewhat harsh on Marmoleum floors, so if vinegar is your cleaning tool of choice, just remember to dilute. Additionally, you may to consult some online testimonials to determine the best brands of vinegar to use for floor cleaning.
Tip #3 - Select the Proper Type of Cleaning Product
If you choose to clean your Marmoleum flooring with a commercial floor cleaner, make sure it is a product designed to clean linoleum. The best types of linoleum cleaners can be purchased from Marmoleum dealers and various online retailers. Should you choose a less specialized cleaning product, however, make sure its packaging states that it is safe to use in conjunction with linoleum. Also, if you're at loss for what brand of floor cleaner to use, you may want to seek out online consumer testimonials from other Marmoleum floor cleaners.
Tip #4 - Don't Neglect Your Floor Grooves
Marmoleum floors tend to have deeper grooves than other types of flooring. These grooves often act as veritable breeding grounds for bacteria, so when cleaning your floor, take care to pay special attention to the grooves. The most effective tool for groove cleaning is a small nylon brush that has been lightly dipped in a mild detergent. However, be careful not to allow the detergent-dipped brush to come into contact with your Marmoleum floor. If you want to be extra-cautious, simply line the edges of your floor with strips of masking tape.
So there you have it. When cleaning your Marmoleum flooring, remember to carefully consider these four tips and your floor will be spotless in no time. Enjoy your freshly cleaned floor!
 forum activity
