4 Tips for Hanging Wall Sconce Lighting Fixtures
Wall sconce lighting fixtures are a very popular type of light fittings that are ideal both for practical and decorative purposes. Wall sconces are a good way of decorating a room since they can be selected to match the décor of the particular area where they will be placed. There is a nice selection of wall sconces available for sale ranging in design, style, dimensions, materials and colors. In order to hang wall sconce lighting fixtures one should keep several tips in mind.
1. The Amount of Wall Sconces to Be Hung
Prior to deciding how to hang them you need to determine which wall will be used for hanging the wall sconces. Depending on the area of the room you then need to decide how many wall sconces are required to provide enough light and use up the area available efficiently and effectively. If a large area is available, the best thing to do is probably hang more than one wall sconce. However, it is important not to overdo it.
2. The Size and Arrangement of the Wall Sconces
The number of wall sconces hung will also be affected by the size of each one of them. You have to make sure to choose wall sconces of a dimension that does not look too bulky or too minute. If there are already some other hangings and decorations present, such as paintings, the size of the sconces have to be in proportion with the size of these other decorations so that they may complement each other. Wall sconces may create a pleasant effect if they are placed on either side of a large painting, for example. However, there may be instances where it may be enough to hang just one large wall sconce right in the middle of the wall, as it can be considered a focal point. In such a case it is best to choose a wall sconce with large lights and intricate designs.
3. Positioning
Since these wall sconces are going to be used mainly for lighting purposes, it is important to bear in mind to install them in a position which will allow the light to be well utilized. This may require them to be placed a bit lower down so as to ensure that the light may reach well towards the ground or above a table. The level they are placed in is important, as is the aspect of the space left between each one of them.
4. Procedure
Use a pencil and a tape measure to mark a line where you will hang the wall sconce. It is best to take into account the factors mentioned previously and also the height of the ceiling. You may also wish to make use of a leveling tool, so as to manage to hang the wall sconce accurately. Then fix the wall sconce firmly to the wall by means of screws. Make sure it holds well and does not tilt to one side or the other, but do not over tighten the screws. Choose screws that are large enough to hold the wall sconce, according to the size of the sconce itself.
Try to keep these basic guidelines in mind when hanging wall sconce lighting fixtures so as to avoid buying unsuitable fixtures and producing unsightly wall displays.
