Login Error
Close
4 Tips for Installing a Reverse Osmosis Faucet
by DoItYourself Staff
Installing a reverse osmosis faucet can provide you with a way to get direct access to pure water any time that you need it. Instead of using a traditional reverse osmosis filter, you can simply turn on the tap and get clean water. When you install this type of faucet, there are a few things that you need to keep in mind. Here are some tips to remember when installing a reverse osmosis faucet.
1. Get the Right Size
When you are installing this type of faucet, you will have to put the filter and the storage tank under the sink in the cabinet. Because of this, you have to make sure that you get the right size for the job. Before you purchase the system, you need to use a tape measure to determine how big of one to buy. Get the exact dimensions of the area that you have under the sink and do not forget to allow for plumbing. Try to get as big of a tank as you can fit under your sink. If you can find one that is 5 gallons, this should provide you with plenty of water in most cases.
2. Handle the Filter
When you get the reverse osmosis system set up, you will have to install the new filter into it. This filter is generally sealed up in a plastic bag with a special liquid surrounding it. This is done to prevent germs and bacteria from getting on the filter. Since the filter is responsible for cleaning your water, you want to make sure that it is clean before installing it. Because of this, you should get some plastic gloves to handle the filter when you open the bag. If you handle it with your bare hands, you will potentially get bacteria on the filter and the reverse osmosis process will not work effectively.
3. Drilling the Holes
In most sinks, you will need to install a new hole for the reverse osmosis faucet to come up through. This will work in much the same way as installing a sprayer hose into the sink. You need to use an electric drill with the proper sized bit to bore a hole up from the bottom of the sink. Wear protective goggles while you are doing this so that you do not get any pieces of the sink in your eye. This will provide you with the opening for the faucet. You should also drill a hole approximately 5/16 inch into the drain line coming out of the sink. This will allow you to hook up the waste line coming out of the filter so that the impurities can be drained out.
4. Be Careful
When you are handling the components, be sure not to inhale any fumes or dust. The liquid that the filter is shipped in can make you sick if you inhale any of the gases that it puts off.
 forum activity
