Login Error
Close
4 Tips for Installing a Window Air Conditioner Bracket
by DoItYourself Staff
Installing a window air conditioner bracket is not rocket science. It is very simple but some tips and tricks can be learned to make life easier for this part of the installation. For most homes and offices, an air conditioner is one of the most essential appliances they could have. And for window air conditioners, they have many advantages and one of them is saving the much needed space. This is possible because this unit is perfectly placed up the wall. And for this, it needs the much needed support to keep it up there. These are the brackets of the air conditioners. These brackets provide the essential need to hold the air conditioner into place.
Check for Durability
Window air conditioner brackets are there to provide support for your air conditioning unit for as long as it takes. An air conditioner is an investment, and it only deserves the best bracket out there in the market. For you to be able to achieve a long time workability of your unit, when choosing a bracket, you should check for the durability of it. It should be compatible to the size and the weight of your air conditioner so that it would be able to hold your unit for many years to come.
Provide Additional Support
In order to ensure the safety of your air conditioner, successfully installing a window air conditioner bracket does not end you job. You have to be able to back the bracket for it to hold your unit properly. You can get some mounting kits to support your air conditioner bracket in the local hardware and screw it to the bracket. By doing this, you are ensuring double safety of your air conditioner from falling off. Also, it would be advisable to make sure that the screws are properly and tightly done to prevent squeaking of the bracket which also weakens the support for these air conditioners.
Reinforcement
Aside from having your air conditioner properly screwed from all the holes you have made with your drill, you also have to consider having the air conditioning bracket firmly welded upon the steel frames of your windows and connecting to the rear of the window air conditioning bracket.
Fitting Check Up
Before even installing your air conditioner, you first have to make sure if your installed window air conditioning bracket fits perfectly to the wall you have made on your window. This will eventually prevent damage of your unit and to make sure it doesn’t move up and down which is the primary cause of rusting for some units.
Make Sure it is Burglar Safe
A lot of people are taking the necessary safety measures to live our lives normally. So before installing a window air conditioning bracket, make sure that the location where you are going to make a hole is high enough for the burglars wouldn’t be able to reach for the air conditioner’s rear and push the unit through your window. Also, when the air conditioner is strategically placed up high, it regulates the temperature more compared to when it is too low.
 forum activity
