Login Error
Close
4 Tips for Installing an Automatic Garage Door Opener
by DoItYourself Staff
An automatic garage door opener is something that is there to make your garage door much easier for you. You will find that with one that will open automatically for you, this a lot less stress and worry that you will have to deal with. Having to open a garage door manually is something that can be exhausting and a hassle to deal with. Installation of an automatic garage door opener is something that is easy to do.
Understand the System
One of the most important things that you can do for yourself is to understand the system. You will find that the more that you know about how it works and what makes it tick will actually make installation a lot easier. It will also help you with maintenance and troubleshooting down the road if anything goes wrong. The heart of your automatic garage door system is made up of an electric motor. This motor is mounted onto the drive track that is along the centerline of your garage door. This electric motor is basically what runs the show.
Instructions
The kit that you get will definitely come with instructions. It is important that you read these instructions thoroughly before you even begin. Make sure that you understand what each of the steps say and know what is expected out of you before you begin. Every automatic garage door is different, so you are going to have to make sure that you know the specific steps that are necessary with the one that you have. Always keep the instructions, even after you are finished. You will find that they will come in handy should you ever have to take the system apart years down the road for maintenance or troubleshooting. The instructions will also be able to tell you what force to apply whenever you are opening the door. You will also be told how high it can raise and how low it will descend.
Materials
Make sure that you know all of the materials that you will need and that you have them out before you even begin. Having all of the necessary items nearby before you start is a great way for you to be able to get the job done quickly and effectively. Having to stop after every step to get more materials is going to end up adding a lot of time to your job and may make your work suffer.
Secure
Something that you will need to think about is the fact that these openers are very heavy. This means that it is very important for you to make sure that they are properly secured to your ceiling joists. If there is not a ceiling joist to secure them to, then you will need to have something else that is just as sturdy of a frame. Whenever you are working with something that is so big and heavy, it is always a good idea for you to be able to have a friend help you so that you can do this task safely.
An automatic garage door opener is something that is there to make your garage door much easier for you. You will find that with one that will open automatically for you, this a lot less stress and worry to deal with. Having to open a garage door manually is something that can be exhausting and a hassle. Installation of an automatic garage door opener is easy to do.
1. Understand the System
2. Instructions
3. Materials
4. Secure
 forum activity
