4 Tips for Installing OSB Sheathing
OSB sheathing is a special type of board that is well engineered; its composition is strands of compressed wood. The strands are layered and are unionized together using a resin. It differs from commonly used plywood in many aspects. It does not have voids or knots, gaps and laps. In several applications, the OSB sheathing has manifested superior strength than plywood boards that are dimensional. A lot of builders are considering OSB sheathing not just because of its strength but because it is inexpensive as well. This kind of material is actually a practical choice. If you consider money to a determining factor, then this will be a good choice.
Before Installation of OSB Sheathing
When you intend to install OSB sheaths, try to determine the breadth or the ideal measurement of your choice for OSB sheathing. This is usually a prerequisite in building codes. There are also alternative choices for the thickness of OSB sheathing. You may choose between sheets that measure 1/2 or 3/4 inches thick. OSB sheathing has different textures on both sides, the other side has a polyurethane coating and it shields the object from natural elements such as moist or water. But on the opposite site, it does not have a finish at all.
Be Particular about Your Framing
You cannot install your OSB sheathing directly. For any material that you want to use as your wall or flooring, frames are essential. There are actually a lot of options available when it comes to frames, but wooden frames are the most preferable. It will be a good thing if you have a well structured frame; it is where the strength of your wall or flooring is relied upon. It is actually being reinforced by the exterior installation of OSB sheathing. If the frames are well structured, it will be supported further by the exterior well furnished material.
Consider the Positioning of Your Installation
The sheathing panels can be horizontally or vertically installed. It can either be across or parallel to the supports. The coated side of the board should face outwards when installing the sheaths. This is to ensure better protection from natural elements such as moist or water. In addition, if you want to have a double layer protection from moist, it will be good to apply several coatings of primer for interiors to the other side of the surface prior to installation of the OSB sheaths.
Things to Note when Installing the Sheaths
When installing the sheaths, there should be gaps amid panels. Usually, it should be about 3mm. The same goes for around the apertures for doors and windows. The distances of nails from the sheaths edges should also be considered to make your installation firm. It should be around 10 mm. It will also be good if you can place some insulating foam within the frame before enclosing the wall with OSB sheaths. The cuts of these insulating foams should be precise; it must follow the exact measurement of every division in the frame.
