4 Tips for Spacing Drywall Screws
You can hang drywall in a variety of ways, but the best way is to use drywall screws. These screws are specially designed to work with drywall by drilling into the stud as well as the gypsum without destroying the drywall. If drywall is not properly hung, it can fall off the studs. It will also not protect against drafts, nor will it allow for proper taping or adding drywall mud. This is what makes spacing drywall screws incredibly important when hanging drywall. The following article will share with you several tips on how to properly space drywall screws to make them more effective.
Use a Stud Finder
A stud finder is an invaluable tool used by construction professionals all over the world. The stud finder is important when fastening drywall to the studs. It will help you find the studs as well as lineup the drywall screws along a line that is the center of the stud.
Conduct a Slap Test
Drywall can be fastened to studs using drywall screws by installing several along the studs from the ceiling to the floor. If drywall is not properly secured, it can fall off the studs or be completely ineffectual when trying to keep out wind. Since the drywall screws indicate where the studs are, it makes easy to conduct this test. Simply strike the drywall stiffly along the seams prior to taping. If you can hear the drywall slapping against the studs or rattling, then there are not enough drywall screws. It can also indicate that some of the drywall screws may not be deep enough.
Use a Marker
Drywall screws are not expensive, and as such, there is no real maximum you should use. You can save some money by not using too many of them, but you cannot use too little or else the drywall will not hang properly. A good starting point is installing drywall screws at the top and the bottom of the drywall with two inches of clearance. Use a tape measure and measure down from the top screw and put a mark at about every 8 inches until you reach the final screw. Place drywall screws at each of the marks you made.
Chalk Lines are Useful
One tool that is used often is a chalk line. This is essentially a string coated in chalk that you pull tight and then snap. Once the string strikes the surface, it leaves behind a perfectly straight line of chalk. You can use this chalk line to properly line up the drywall screws as well as keeping them straight and centered on the studs. Use the chalk line in conjunction with the marker and measuring tape to create properly spaced drywall screws that are also straight and centered. This works horizontally as well as vertically. After you create the chalk lines spanning the height of the drywall by the studs, you can also use it along the width of the drywall going through each mark you made. The end result will be a grid pattern.
