Login Error
Close
4 Tips for Spreading Pea Gravel
by DoItYourself Staff
Pea gravel is a common material used for landscaping. It basically refers to a gravel mix that consists of flat round stones. Pea gravel is popularly used in walkways, driveways, gardens, concrete floors, and home aquariums. There are a number of advantages of using pea gravel. To begin with, it is an eco-friendly addition to any setting. Also, it looks really good without costing you an arm and a leg. Moreover, it does not require much effort in terms of maintenance. Pea gravel is also useful apart from being aesthetic; spreading out pea gravel helps add grip to the area. It is also useful in optimizing drainage in the area it is laid out in. Additionally, it helps prevent weeds and other pesky growth in the marked area.
Pea gravel is available at all home improvement and gardening stores. How much pea gravel you’ll need depends on the project at hand. When considering pea gravel for your home, remember the key to the perfect look lies in the proper spreading of pea gravel. This is what makes all the difference. If you are considering using pea gravel, the following 4 tips for spreading pea gravel will be useful. Before you begin spreading the pea gravel, be sure to mark the area you plan to work on. Also, you need to clear the space and make sure that there is no debris before you begin work.
1. Place a Weed Barrier
Before you begin spreading out the gravel, you need to spread out a weed blocking fabric on the cleared ground. These are available at most home improvement and garden stores. This material allows water to seep through, but hampers weed growth.
2. Collect the Gravel
Collect the pea gravel in a wheelbarrow. This proves very convenient along the way. Place the wheelbarrow along the perimeter of the area you are planning to lay. Consider areas that might become inaccessible or inconvenient later in the process; this includes the bases of plants along the edges. Now using a regular garden shovel, spread the pea gravel along these areas a little at time.
3. Make Little Piles and then Rake the Gravel
Once you’ve tackled the difficult corners, create little piles of gravel along the work area. Space the piles with gaps of about 2 feet. Once you’ve set up all the gravel, use a garden rake to flatten the piles of pea gravel. Make sure you flatten the gravel in a uniform manner. Pat down in areas where it seems uneven. Fill in the bare sections and make sure you distribute the pea gravel evenly.
4. Let the Pea Gravel Settle
Once you’ve spread out the pea gravel, it is important that it settles down. There is a very simple process for getting this done. Pull out your water hose, connect it to the garden tap and water down the pea gravel for a few minutes. If certain sections are jutting out, tap them down. Let the gravel sit for a while before using it.
 forum activity
