Login Error
Close
4 Tips for Using a Paint Roller
by DoItYourself Staff
If you don't have much experience with using a paint roller, you may be wondering how to properly operate one. Fortunately, using a paint roller is a very simple task, particularly if you're armed with a helpful set of tips. So if you're eager to start using a paint roller, read on to learn the basics.
Select the Right Type of Paint Roller
Before getting started on a painting project, you must select a suitable paint roller. As you will be applying a steady amount of pressure to the roller, make sure to select one that features a strong frame. Also, if you intend to use your roller to apply paint to a ceiling, purchase a roller whose handle features a threaded end. This will enable you to add an extension pole to the roller, thus eliminating the need to stand atop a ladder when applying your paint. In addition, you will need to select a roller sleeve that is equipped to handle the surface you intend to paint. If your surface is of a smooth consistency, 1/2 nap sleeves should suit your purposes. However, if your surface is of a rougher texture, the job will probably require a 3/4 or 3/8 nap sleeve.
Prep Your Paint Roller
Now that you've selected a suitable roller, you're ready to begin applying paint to your chosen surface. Start this step by placing your sleeve over the roller. If you are using a latex-based paint, lightly dampen your roller with water. Alternatively, if you're working with an alkyd-based paint, gently dip it in solvent. Once your roller has been dipped into the paint, carefully run it across a protective absorbent surface to roll away any excess paint. This will help keep paint drips to a minimum.
Use Proper Strokes
When painting with a roller, take care to produce an "N" or "M" shaped pattern with your initial coat of paint. Next, go over the first coat with a second coat that should be applied in a straight bottom-to-top fashion. Make sure to smooth out any paint ridges with a paintbrush shortly after they are formed, as they will be considerably more difficult to get rid of if given ample time to dry. Also, make a point of not scraping the edges of your surface's corners with your paint roller. Instead, you may want to use a paintbrush to apply paint to the corners of your surface.
Properly Store Your Roller
If you're taking an extended break or want to quit painting for the day, wrap your roller in a wet rag or plastic wrap. If you're working with latex-based paint, however, you will need to store your roller in a bucket of water. An improperly stored paint roller will not last long, so make sure to properly care for your roller.
When using a paint roller to apply paint, just remember these helpful hints and you'll have no problem operating your roller.
 forum activity
