Login Error
Close
4 Tips for Using Septic Tank Additives
by DoItYourself Staff
Septic tank additives are being used by mainly homeowners, as most professionals do not like using them for one reason or another. Over the last few years, there has been a lot of research done to create septic additives that are useful to septic tanks and not destructive. There are many kinds of septic tank additives that can enhance the operation of the septic tank. There is no solid or concrete proof that septic tank additives will damage or harm your septic tank in any way, shape or form. When you use septic tank additives, you should do so with normal maintenance and not in place of it. The information contained below will help you to properly dispense of septic tank additives as well as explain some of them.
1. Using Inorganic Compounds
Septic tank additives consist of strong chemicals, such as acids and alkalis. These are the same chemicals that are used in products used to unclog clogged pipes. This is the same purpose that inorganic compound additives have on the septic tank. Of course this is at a much greater scale than your home pipes. Some of the chemicals most notably found in these additives are lye and sulfuric acid. Many studies say that these additives can damage the pipes and tank and, therefore, should not be used. Another issue is that these septic tank additives can destroy other treatment compounds that you may already be using. Hydrogen peroxide is one of the inorganic compounds used in septic tank systems as a way to recondition the infiltration field, but it has actually been discovered that it damages the field. Do not let this scare you away from these products, as they can reset the septic tank. Using the chemicals will allow you to get the proper balance of naturally occurring chemicals.
2. Organic Solvents
These include methylene chloride and trichloroethylene and are used to degrease septic tanks. You'll find these promoted as a way to break down greases and oils. Many present a significant risk as they can seep into the ground and waste water of the septic tank. Septic tank chemicals of this variety can kill off naturally occurring decomposers and other kinds of microorganisms that are helpful within the treatment process. Many states have banned the use of organic solvents in onsite systems. This is due to the possible damage of the ground water. If your septic tank is completely sealed off from ground drainage, then organic solvents can help the process of your septic tank system.
3. Biological Additives
These types of chemicals mirror the regular decomposition found in septic tanks. They do not really enhance this normal function but do not hinder them as well. Be very careful when using these septic tank chemicals, as some can degrade the sludge and scum found in a septic tank.
4. Phosphorous Removers
Septic tank chemicals that are touted to remove phosphorus are useful when watershed residents experience eutrophication. This problem can cause algae growth in nearby waterways. This chemical will help to prevent that from happening.
 forum activity
