Whenever you are working on ceramic tile repair it is important that you are aware of the necessary steps and tips that you should take so that you can get the job done properly. Repair on ceramic tile is something that you should do only when you are fully prepared, knowing what to expect is one of the most important things about the job.
New Tile
Whenever you are getting the new tile, it is important that you make sure that you take the old tile with you. Whenever you take the old tile with you, you will be able to get the right tile without worries. It can be very easy to get replacement tile that is just slightly off without realizing it until it is too late and you have already brought it home. Save yourself another trip back to the store by taking the old tile with you. Whenever you are at the store, it is always a good idea to purchase more tile than you need so that you will not have to worry about doing this part the next time you need to make repairs.
Tile Removal
It is important that whenever you are removing the tile that you do it slowly and with the right tools. You will need to make sure that you use a chisel to get rid of the old grout that is surrounding the tile. In addition to the chisel, you will also need a hammer so that you can get the chisel underneath the tile whenever you are removing it. You will also need to make sure that the floor is as smooth as possible whenever you are removing it. The old grout as well as the adhesive needs to be scraped from the floor. The smoother the floor is, the longer the new tile will stay in place.
Dry Time
Once you have successfully laid the tile, it is very important that you allow it to set for the right amount of time. The tile should set for at least 24 hours. Once the tile has had time to set, you will be ready to apply the grout. The tile will need this time to set so that it can set properly for the remainder of time that it will be there. Not allowing the tile time to dry could result in it not being laid properly and sticking like it should. The grout should not be applied and the tiles should not be walked on until they have had the 24 hours to completely dry. You will need to make sure that you completely clean up the area of extra grout as well as any filmy residue before it has completely dried. Allowing it to dry this way will make it especially difficult and nearly impossible to remove later on.
Safety
Safety is one of the most important parts of any project. You will need to be sure that you are wearing safety goggles. Take your time and do not get into a hurry whenever you are removing the tiles.
Working with ceramic tile repair can be tricky if you aren't sure of the process. Ceramic is difficult to work with, and is easy to chip and crack when working. Here are several tips that will make the job simpler.
New Tile
Tile Removal
Dry Time
Safety
