Login Error
Close
4 Types of Gazebo Covers to Consider
by DoItYourself Staff
Gazebo covers are an essential feature of a gazebo. The cover consists of a large piece of material that shelters the gazebo from rain and sunlight. This allows you to enjoy the comfort of your gazebo regardless of the weather. The cover also gives the structure some degree of protection from the elements. It helps to extend the longevity of your gazebo. The right choice of canopy goes a long way to complete the appearance of your gazebo. Different types of covers are available on the market. Below are 4 types you may wish to consider.
1.   Canvas
You’ll come across an endless selection of colors, patterns and designs of canvas canopies. This makes it easier to achieve whatever look you desire for your gazebo. The heavy duty nature of canvas makes it suitable for a wide range of outdoor applications. It is one of the most resilient and hard wearing materials you can select for a gazebo cover. Canvas is generally thick, which helps to keep out most of the rain. It comes in different ounces with the heavier types being much stronger. Some manufacturers incorporate a water resistant treatment during manufacture. Canvas can also be treated to make it flame resistant which enhances safety outdoors. These qualities contribute to the high durability of canvas canopies. However, canvas covers are amongst the most expensive on the market.
2.   Vinyl
This is one of the lighter materials you can choose to cover your gazebo. Vinyl is available in various colors and textures. This enables you to achieve your desired décor with ease. It is a waterproof material which helps to keep you well sheltered from the rain. Vinyl is much lighter than canvas. Installation of a vinyl cover can be done faster due to the lightweight nature of the material. The downside of vinyl is that it is susceptible to quick wear and tear due to exposure to the elements. However, vinyl is one of the more affordable materials for gazebo canopies.
3.   Cedar Shingles
If you have a wooden gazebo, you may want to consider cedar shingles. They complete the appearance of a wooden gazebo perfectly. The gazebo also blends in naturally with the outdoors. Once you purchase cedar shingles, you may choose to install them yourself. This helps to cut down on costs. The down side of cedar shingles is that they can be attacked by mold and mildew with time. This is because they tend to absorb moisture which makes this conducive for the development of mold. Cedar shingles are also susceptible to rot and damage by insects.
4.   Metal
This is one of the cheapest materials for gazebo canopies. Cast aluminum, wrought iron, and steel are some of the commonly used metals for gazebo canopies. The advantage of a metal canopy is that it is very durable. It does not easily break or show other signs of wear and tear. Metal canopies have a high impact resistance and do not easily loose their form. The waterproof nature of metal further adds to its suitability for canopy use. You however must take steps to prevent rust and corrosion which is a common problem with a metal canopy. This calls for periodic application of paint.
 forum activity
