4 Types of Greenhouse Plastic to Use
There are a lot of different benefits to using greenhouse plastic for building your own greenhouse. They are very easy to build and cost much less than a large glass frame. The plastic is what is going to maintain the heat and humidity in the greenhouse. Depending on the type of plastic that is being used, you can grow a wide variety of flowers even when the winter weather sets in.
What Is Greenhouse Plastic?
Greenhouse plastic is made to be more durable than regular plastic. Regular plastic sheets will tear easily when cut because its ends fray. Greenhouse plastic is specially made to resist tearing and stand up to weather much better. Greenhouse plastic is actually knitted instead of formed into sheets.
This type of plastic is prefect for wrapping around different sizes and shapes of greenhouses, and be framed around vents, doors, and windows. Greenhouse plastics are the preferred coverings for greenhouses today as it lowers the actual costs of constructing a greenhouse.
Greenhouse plastics are mostly made out of four different types of plastic. Most generally, these plastics will all last about 2 to 3 years before they need to be replaced. Of course, this does not take into account extreme weather such as hurricanes, tornadoes, hail, and severe icing.
Polyethylene Plastic
The first type of greenhouse plastic is called polyethylene plastic. This type of plastic is also available in two different strengths. These are commercial grade for large industrial applications and a utility grade for personal use. Most home centers will carry the utility grade and is mostly used by gardeners constructing their greenhouses. Polyethylene plastic will last for a year or two when kept in good condition. Smaller tears can be repaired with a poly repair kit.
Copolymer Plastic
A grade above the polyethylene plastics is the copolymer plastic. It is a little more durable and longer lasting. It can last on your greenhouse upwards of three years before it begins to turn brittle and break. The freezing and thawing of the plastic will cause it to be brittle after a few years. There are also more expensive copolymer plastics that are even more durable and will mimic the effects of glass.
Polyvinyl Plastic
This is the more expensive type of plastics as compared to the other two. However, it is also more durable than the previous two. Greenhouses covered over in polyvinyl plastic will benefit from the strength of this plastic. Replacement does not have to happen until after five years if you have taken good care of it with regular cleaning and inspection.
Polycarbonate Plastic
The most durable of all the greenhouse plastic is called polycarbonate plastic. It is actually a double, or a twin wall, polyethylene plastic. It can last for up to a decade if cared for correctly. It will also maintain a lot of heat and humidity for year round growing.
If you are building, or thinking of building, a greenhouse, look into these greenhouse plastics for an inexpensive and easy do it yourself greenhouse option.
