4 Types of Outdoor String Lighting Options for Your Yard
Most people associate outdoor string lighting with the beautiful, multicolored strings of incandescent light that are used to light up buildings and Christmas trees during the festive season. What most people don’t realize is that these lights can also be used after the festivities are over.
String lights can be used both outdoors and indoors. They are an energy-efficient, unobtrusive and cost-efficient way of lighting up your surroundings. These subtle lights can help to highlight the most beautiful features of your house or your yard.
The single most important thing to keep in mind when choosing outdoor string lighting for your yard is to ensure that the light has been designed to be used outdoors. This is because lights that are designed to be used outdoors will be more durable and incorporate weatherproof elements that protect them from the environment. Let us take a look at some of the options that are available in the form of outdoor string lighting for your yard.
1. Incandescent Light
Incandescent string lights have been traditionally used to decorate houses and trees during Christmas. These lights are inexpensive and are available in different sizes, shapes and colors. You can use these lights to decorate your home or yard for a special function. Whatever the occasion, you will find an incandescent string light that meets your requirements.
However, in spite of their myriad advantages, incandescent lights also have a few major disadvantages. The single biggest problem with incandescent lights is that they can become quite hot when lit and may pose a fire hazard if not installed properly. The life of incandescent light bulbs is also not much, and you may have to replace the light bulbs on a regular basis.
2. LED Lights
LED (Light-Emitting Diode) string lights are now the most popular choice in outdoor string lighting. These LED lights consume far less energy as compared to incandescent lights. What’s more, since LED lights do not become as hot as incandescent lights, they significantly reduce the risk of a fire. LED light bulbs also last longer as compared to incandescent lights.
Although LED string lights are slightly more expensive than incandescent lights, their many advantages make them the optimum choice for outdoor string lighting.
3. Solar-Powered Lights
LED lights can also be hooked up to a solar panel to transform them into solar-powered lights. These lights use the least amount of energy because they use sunlight as a source of energy. LED lights are the most suitable for use as solar-powered string lights because they consume the least energy. These solar-powered string lights can be set to come on automatically when it becomes dark outside, and to switch off once daylight dawns again.
4. Marine Rope Lights
Marine rope lights are another excellent option when it comes to outdoor string lighting for your yard. These lights are so called because they are mainly used in sail boats. They consist of transparent rubber tubing that encases continuous strings of lights. Due to the presence of the tubing, the lights are completely protected from the elements. This makes them ideal for marine use and also makes them very good for outdoor string lighting.
