Login Error
Close
4 Types of Screw Guns Explained
by DoItYourself Staff
Screw guns are very useful tools used by various craftsmen to hang drywall, frame houses or install roofing. A screw gun allows a user to quickly and efficiently install screws wherever they are needed. There are several primary kinds of screw guns on the market that you can buy. Read on to learn about cordless, autofeed, drywall and collated screw guns.
1. Cordless
Cordless screw guns come in many styles and sizes, which make them perfect for using at home or on a job site. A cordless screw gun runs off of battery power, which makes it easy to use anywhere.
On the downside, you sacrifice convenience for performance because the power is not steady. The battery can also quickly fail, even with minimal use. The other problem is that the power of cordless screw guns is limited in smaller home versions. There are cordless models meant for builders, but you will pay a premium price for them.
2. Autofeed
One complaint that is universal is that screw guns take too long to use. When this happens, a nail is sometimes substituted because it is easier and faster to install. With most screw guns, you have to set the nail or drill a pilot hole. You can then place the bit in the thread of the screw and power it in the surface.
Autofeed screw guns operate on a clip of screws. The screws you intend to use are on a plastic sheet that you feed into the screw gun. When you use the gun, you install the screw and it rips itself away from the plastic. The sheet then advances and loads another screw for you. This makes the process simpler and faster.
3. Drywall
Hanging drywall is a delicate process that can be very tedious. If a drywall screw is placed too deep, it can crack and break the drywall. If the drywall screw is too shallow, the drywall will most likely come free and cause serious problems down the line. Drywall screw guns are specially made so that the screw can not be sunk into the drywall further than it should be. You can also find these screws guns with autofeed options, making them incredibly easy to use as well as quick.
4. Collated
Collated screw guns are an interesting tool that many builders are quickly determining to be a must-have tool in their arsenal. A main concern among framers, drywall hangers, roofers and deck builders is that screws can come loose and cause problems to arise down the line. To correct this potential problem, it is recommended that you sink the screw below the surface of the wood. This is possible with a collated screw gun as it will drive a screw 2 inches below the surface. There is also a drywall attachment.
 forum activity
