Login Error
Close
4 Types of Septic Tank Treatments Explained
by DoItYourself Staff
Septic tank treatments are vital to the maintenance of your septic system. The tank, drain field and soil all serve important roles in the way the system operates. Septic systems help to properly and safely dispose of wastewaters. These waters are produced from kitchen, bathroom and laundry use. Due to the presence of a high content of germs in the wastewaters, it is crucial that you have an effective treatment program. Below are 4 treatment plans.
1.  Bio-Culture Additives
Bacteria colonies naturally occur in sewage systems. They play a vital role because they enable the system to work at its best. When added into the septic system, bio-cultures enhance the way colonies of bacteria work. They reinforce the natural biological processes at work in the septic system. These cultures are very useful when clogged leach fields require to be cleaned. Further, bio-cultures have a high efficacy as a remedy for encrusted build-ups in sewerage systems. They also work to reduce the effects of pollution by household wastes.
2.  Use of Filters
It is a good idea to install an effluent filter in the septic tank’s exit baffle. This feature prevents the discharge of large solids into the drain field. You need to have the filters cleaned whenever the septic tank is pumped. You should also use washing machine filters to minimize discharge of solids into the septic system. Effluent and washing machine filters go a long way to protect your septic system.
3. Septic Tank Pumping
When sludge is pumped from the sewerage system, it reduces the load on the system. The flow of wastewaters into the system is also moderated when the tank is pumped. This reduces the amount of sludge flushed into the drain field. It also provides the septic system and drain field with an opportunity to rest. The reduced incidence of chemicals from household cleaners and bleaches increases the working capacity and efficacy of the bacterial colonies. These colonies get ample opportunity to act on the biomat that abounds in the drain field. It is a good idea to have the septic system pumped every 3 to 5 years. This helps to prevent leach field failure, a common occurrence where systems are not drained regularly.
4.  Regular Maintenance
A rigorous maintenance schedule is one of the most effective treatments for your septic tank system. An annual inspection of the septic system is also a good idea. Some techniques can be put in place to reduce the load on the system. Responsible usage of water in the household is a key measure. Excessive use of water floods the septic system. It also causes discharge of more solids into the drain field. If you spread out household water use, it can help keep the system from too much strain.
You should also reduce use of water softeners. Softeners increase discharge of water into the septic system. It is best to use a softener that doesn’t use high volumes of water. You must also prevent the disposal of garbage into the sewerage system so as to reduce the volume of solids in the systems.
 forum activity
