4 Uses for Landscape Blocks
Landscape blocks are preformed blocks of concrete often referred to as “pavers.” They are occasionally confused with standard bricks, which are composed of a different material. Landscape blocks have found great favor with both landscape designers and homeowners due to their versatility as a building material. The four applications described here exemplify their creative and functional appeal.
1. Build a Garden or Yard Boarder
Stacking several layers of landscape blocks around the perimeter of your flower beds or your entire yard is an inexpensive way to increase your home’s curb appeal. Bordering your yard or flower beds with landscape blocks is as functional as it is classy.
A flower bed enclosed by landscape blocks is far easier to maintain than an open plot of land. This is due to the fact that the blocks protect the rich topsoil from erosion and prevents lawn grass from encroaching on the bed.
2. Build a Compost Bin
Landscape blocks are easy to stack and can be adhered to each other in an infinite number of forms and shapes. For this reason, landscape blocks are the perfect material to use if you wish to create a sturdy and long-lasting compost bin.
Using landscape blocks to construct a compost bin gives you the freedom to choose the dimensions of the structure. In addition, you may decide whether or not you wish to have an open-faced or completely enclosed compost bin because you’re completely in charge of the building process.
Start by laying out the perimeter of what will become your compost bin by using a layer of landscape blocks. After confirming that you have a level building surface, you may use concrete and pavers to vertically expand the structure until it fits your specifications.
3. Use Landscape Blocks to Build a Retaining Wall
Landscape blocks are the perfect material to build a retaining wall, considering their ability to be neatly stacked in combination with the strength of the cement they are composed of. Landscape blocks make an excellent retaining wall because it blends in with its surroundings and appears natural.
Also, once the retaining wall is established, it can be treated like a rock garden. Populate the small spaces between and around the landscape blocks with various climbing species of plants.
4. Use Landscape Blocks to Build a Path
Landscape blocks look gorgeous when they are laid out to form a path around a garden or back yard. Instead of using dirt, gravel or woodchips to create a path throughout your space, consider employing landscape blocks. Not only are landscape blocks easier to maintain than other path building materials, but they give off an air of professionalism and transform a yard into a manicured sanctuary.
