Login Error
Close
4 Waterproof Bathroom Wall Options
by DoItYourself Staff
There are many bathroom wall options that can be used to create a waterproof bathroom wall. It is important that a bathroom wall is waterproof because, if not, serious problems may occur. A bathroom wall that is not properly waterproofed will allow water to not only get into the wall but into the floor and all floors below the shower. When this type of leak occurs it can go on for months and months without you even knowing it is present. Over time you can suffer serious leaks and water damage that could cost you thousands of dollars. The article that follows will share with you some bathroom wall options you can utilize to waterproof the bathroom.
Vapor Barrier
This is not a catch-all for water but it can help the wall stay dry from the dampness presented whenever the shower is used. Even if there is no leaking the water can still harm an underlying wall. As the water is used steam rises into the air. If the bathroom wall is not waterproofed then this steam can seep into the wood. This can cause damage over a long period of time but a vapor barrier can be used as a preventative measure. It will stop the dampness from the steam becoming an issue and will help to protect the wall even if there is a leak.
Single-Sheet Plastic
There are many companies that are producing and selling inexpensive bathroom wall finishing options. One of these includes a plastic wall that resembles tile, but is one sheet of plastic. A vapor barrier would be placed on the wall and leading under the tub and the plastic wall is installed on top of that. The wall usually stretches all the way down to the top of the tub and possibly a few inches below and then sealed. These plastic walls can be made in sections but they are also available in sizes that will fully wrap around the shower and can be trimmed for a perfect fit.
Natural Materials
Nothing much comes close to the beauty that exists in natural stone. A bathroom wall covered with natural stone tiles is more water resistant than bathroom walls that are only protected by plastic. Brick is also included as a potential bathroom wall option. Natural stone is naturally protected against water and moisture and will not swear under hot temperatures. Ceramic tile, though hard and secure, can sweat and retain moisture.
Sealant
Whenever a bathroom wall is built it's important that it be sealed quickly and before you use it as most plumbers will not do this for you. Use the proper sealer for the type of bathroom wall that you have as there are hundreds of products and some are specific to certain materials. Always follow the instructions on the container to the best results. In addition to a bathroom wall sealer that is placed on top of the wall to protect it against moisture there is another crucial sealer. Silicone caulk should be used around all edges and spaced.
 forum activity
