Login Error
Close
4 Ways to Prevent an Overheating Laptop
by DoItYourself Staff
An overheating laptop is a common occurrence which you can prevent by following the tips stated below.
Unplug Your Laptop
Disconnect the power supply of your laptop as soon as the batteries are full. A laptop always connected to a power supply will overheat the batteries of your laptop and the laptop itself.
Work on a Flat Surface
The cooling fan is located at the bottom part, which needs adequate air circulation to prevent an overheating laptop. Laptops are designed to be placed on flat surfaces such as an office or coffee table. Do not place your laptop on the bed or a cushion; instead place your laptop on a desk, stand or lap desk to allow the cooling fan to work properly.
Use a Laptop Cooling Pad
A laptop cooling pad is an effective way of preventing an overheating laptop. It is a tray-like device with numerous cooling fans; you attach it to the bottom of your laptop. A laptop cooling pad is connected to your computer through a USB connection.
Do Not Overwork Your Processor
Open only one application at a time to prevent your laptop process from working too much and overheating in the process.
 forum activity
