Login Error
Close
5 Advantages of Owning a Mini Projector
by DoItYourself Staff
Before investing in a mini projector, it is worth making yourself aware of the benefits that can be gained from owning one. By bearing a few details in mind, you will better be able to decide on the correct choice for your purposes.
Advantage #1 - Space
Owning a mini projector rather than its full-sized counterpart can be a great way to prevent a large amount of space being taken up by the appliance. It is a good option if you have created a minimalist look in your home. Where you do not intend to keep it in a permanent position, it can be stored without taking up much space.
Advantage #2 - Portable
A mini projector will normally be sold with a carry case which will make it easy to transport if it is required in another location. Besides this, it will also be easy to move about in your home as the size and weight resemble that of a cell phone. It can be fitted to a wall or onto a tripod in accordance with what is most convenient for your purposes. This means that a related screen will not be necessary as you can always move the projector to a position where it can be directed towards a clear section of wall that is large enough to accommodate the entire projector panorama.
Advantage #3 - Convenience
Using a mini projector will give the ability to view your media on a large screen that is comparable to many widescreen televisions without you having to go through the related inconvenience and cost. The projector will be a fraction of the cost of a similar sized television and will do the same job. The projector also proves convenient from an energy point of view as it can be either battery or mains powered. Furthermore, where you are concerned about the security of your home when you are away, the projector can be locked away when necessary unlike a wide screen television. The projectors have easy and instant operation and make use of an LED light so that no lamp replacement will be required.
Advantage #4 - Variety of Uses
Where technology allows, the projector can be used with a PC, cell phone, iPod or digital camera for TV output. For example, using the projector to view photographs can make them easier to see than they would be off of a laptop. The range of projectors on the market will allow you to choose a resolution that will work best with the ultimate size of the image to ensure that you get a clear picture. It is especially useful if you want to create a home theater but only have a limited area to accommodate it.
Advantage #5 - Adjustments
A mini projector will comprise of in-built speakers that will enable you to adjust the volume every time it is used to a level that works best for the area it is being used in. In addition, much like a television, an on-screen display will enable to make quick adjustments to the brightness, contrast and color as and when they are necessary.
 forum activity
