5 Advantages of Using a Bathtub Liner
A bathtub liner is a thin sheet of plastic or acrylic that is installed over an existing bathtub. It is molded according to the shape of the tub and finally glued over the bathtub. Bathtub liners come in a range of colors and styles which means they can fit almost any décor. Using liners is often preferred over bathtub refinishing or replacement as it provides several advantages, listed below.
Quick to Install
Having chosen the desired tub liner, the surface of the existing tub should be prepared by spraying denatured alcohol to remove any soap remains or oil residues. Next, the fixtures should be replaced and the new liner should be placed over the bathtub with the use of an adhesive. Finally, the tub should be given a time period of a day to dry, after which it can be used anytime. This whole process of installation usually takes place within a day and no more than one worker is required to do the entire fitting. Replacing a bath tub on the other hand is a time consuming task as it requires you to remove the tub as well as the tiles around it in addition to reinstalling them once the new bathtub is in place.
Relatively Inexpensive
Installing a bathtub liner comes with an added advantage of being relatively light on your pocket. Whereas, bathtub replacement can prove to be quite costly, installing a tub liner with the help of a professional will cost under $2,000, as of August 2010.
Durable
Once a bathtub liner is installed in your bathroom, it can last for years given that the right material is used. Acrylic and PVC plastic surfaces are generally durable in addition to being easy to clean and resistant to damage. In the absence of any grout that needs to be cleaned or replaced, a bathtub liner is almost maintenance free during its lifetime.
Zero Demolition
While replacing a bathtub comes with the hassle of removing and reinstalling the bathtub and tiles, installing a bathtub liner does not require any demolition in the bathroom. Depending on the new tub design that you choose for the bathroom, some plumbing may also be required to remove any studs or to open up a wall. A liner installation on the other hand means that there is no deconstruction in the bathroom or any other additional mess.
Competitiveness
Given that tub relining is quite common these days, it is easy to find a lot of companies that will cater to your needs of getting a new bathtub liner installed. Due to the presence of competition, you can easily find a wide range of colors and styles to suit the décor of your bathroom. Moreover, whichever company you choose will assist you in selecting the right tub liner in addition to getting it installed through a professional for an excellent finish.
