5 Advantages of Using a Copper Chimney Cap
A copper chimney cap is a valuable piece of equipment that is not only useful, but looks good while protecting your fire down below. Copper has long been used for its attractive and durable qualities, from modern kitchenware to ancient armor. Using a copper chimney cap over your fireplace will ensure thorough protection of the chimney it covers and a clean fire burning in your fireplace.
Protection
If you have a fireplace, you may have already pictured a random assortment of objects falling down the chimney. Any number of things have the potential to slide down, from rain and snow, to leaves and even small animals. A chimney cap prevents all these and keeps your chimney free of clogging debris and water that could soak into the insulation most metal chimney's have.
A metal grate keeps larger things out, while overhanging lips protect the interior from water, snow and other finer debris. Some caps have built-in drafts that can increase or decrease the amount of air that gets in; which you choose depends on your own personal need.
Design and Maintenance
All types of chimney caps serve their protective purpose to varying degrees of effectiveness, but copper chimney caps, in particular, look the best while doing it and enjoy a level of durability not found in some other metals. Copper cleans easily and retains the amber shine for extended periods despite being exposed to the elements on your roof.
