Login Error
Close
5 Advantages of Using Solid Rivets
by DoItYourself Staff
Solid rivets are ideal fasteners to use in applications where high strength is desirable. They provide a permanent tamper-proof bond especially useful in aircraft and auto industries. However, rivets are also useful in assembly of tools and clothing. The solid type rivet generally reflects a mushroom-like structure. A narrow tail supports a wide head. Several types of rivets are available for a wide range of uses. Nonetheless, within construction and manufacturing sectors, the most widely used fastener is the solid rivet. Below are 5 advantages of this popular fastener.
1. Cost-Effective
Solid fasteners are amongst the cheapest on the market. However, their low cost doesn’t in any way detract from their efficacy. They provide an attractive alternative to welding and adhesive joints in various assembly operations. This helps to control production costs, which makes the solid rivet a cost-effective means of assembly. Additionally, the lightweight nature of the rivets helps keep transport costs low even when large quantities have to be transported.
2. Increases Production Output
Solid rivets encourage high production rates. The rivets are easy to use and do not require specialized processes or equipment to install. Hydraulic tools or handheld hammers are mostly used to install the rivets. This enables quick assembly of items which helps keep production costs down.
3. Design Flexibility
Several different types of solid rivets are available for a wide range of applications. Some varieties include oval head, round head, brazier head, button head and tubular rivets. The rivets are also available in various designs and styles which meet decorative needs where these factor highly in assembly. Solid rivets can be painted or polished to blend with the work piece. Various finishes can be achieved. This gives greater satisfaction in assembly. The wide range of solid fasteners makes the assembly of items much easier. They can be used with a high level of satisfaction on materials of different thicknesses.
4. High Resilience
Since they’re produced from tough metals, the rivets tend to retain their structure even during installations. Breakages, chipping or deformations are not the sort of occurrence you can expect with these rivets. Once installed, the rivets are bound to last for several years. Solid rivets need two people to install because the joint has to be accessed from both sides. This contributes to a rigorous quality control process. The tamper-proof quality assures manufacturers of high standards during assembly. Replacement due to wear and tear doesn’t arise with solid fasteners. The sheer strength of the rivets adds to their durability. It also adds considerable value to items that incorporate the rivets.
5. Durable
Solid fasteners have a high resistance to corrosion resistance even when subjected to moisture or chemicals. The fasteners are generally made of high resilience metals such as stainless and galvanized steel, titanium, nickel-based and aluminum alloys. Once installed, the rivets generally last several years. They do not easily show signs of wear and tear. This contributes to the longevity of items being fastened.
 forum activity
