5 Advantages to Using a Hydrogen Fuel Cell Generator
A hydrogen fuel cell uses hydrogen as its source fuel to generate an electrical current. The process also utilizes oxygen from the air which acts as an oxidant. As long as the necessary flow is maintained, a fuel cell can operate uninterrupted for a long period. Through electrolysis, hydrogen which occurs in great quantities universally can be harnessed as a useful fuel for various daily applications. With environmental concerns currently taking priority in various arenas, exploring alternative energy is a welcome shift. Below are 5 advantages of using a hydrogen powered generator.
Reliable
Fewer moving parts and the absence of an internal combustion process makes fuel cell systems highly reliable. You’ll hardly experience breakdowns or slow downs with a hydrogen powered generator. Reliability and efficiency remain consistently high. Fuel cell systems produce electric power without being subject to weather changes or market fluctuations. These two factors often disrupt the supply of other conventional forms of energy. The freedom from these concerns adds to the overall appeal of hydrogen fuel cells.
Eco-Friendly
Fuel cell systems offer more ecological benefits than conventional power generation systems. Water and heat are the only byproducts of the electrolysis process involving hydrogen. Hydrogen fuelled generators create less pollution than generators fueled by oil, gas or electricity. Hydrogen fueled systems produce only about half the amount of greenhouse gases associated with other internal combustion engines. Besides, the harnessing of the waste heat and water further reduces the carbon dioxide emissions to the atmosphere. The significantly lower emission rate of hydrogen fueled systems ultimately results in the reduced incidence of smog and acid rain. Unlike internal combustion generators which are prone to get dirty due to the byproducts of combustion, hydrogen powered generators remain clean for longer. This makes them a low maintenance power generation feature.
Economical
Significant savings can be realized by harnessing hydrogen and oxygen for electric power generation. Hydrogen fueled generators are also less prone to breakdowns. The system has very few moving parts which makes them a low maintenance device. The low maintenance feature helps keep costs down over time. It also adds to the durability of the system since replacement rate is low. This makes them a cost-effective option when it comes to power generation.
Efficient
Hydrogen powered generators produce Direct Current electrical power with greater efficiency than most of the other non-renewable generation systems. Internal combustion generators have an efficiency of 15-20% compared to hydrogen powered generators whose efficiency ranges at 30-40%. The waste heat produced from fuel cell systems can be utilized for household heating needs. The heat can be easily transferred to the home using a heat exchanger. This makes the hydrogen powered generator amongst the best when it comes to overall system efficiency.
Convenience
Fuel cell systems are lightweight with no moving parts. The system generates electrical power without the usual noise that is associated with internal combustion generators. It produces only about one quarter the noise that a gas or diesel generator yields. This makes it ideal for residential usage.
