5 Backsplash Maintenance Tips
Having a backsplash is a great way to save your walls from stains and soils, but the backsplash itself also has to have proper maintenance. Each type of backsplash that is installed requires a different type of maintenance depending on the material that it is made of. The tips in this article will help you keep your backsplash looking like new.
Maintaining a Tile Backsplash
In a bucket, mix 1 part white vinegar and 1 part hot water. Using a soft cloth, wipe the tile down with this mixture. Try to get in between tiles to the grout as much as possible. If there are tough stains that are left behind, make a paste with baking soda and water. Use a small brush to scrub the stains. It is completely safe to use the small brush to get inside any indentations in the tile or to scrub in between the tiles on the grout. Rinse the tile completely with clean water and a soft cloth. Use a clean microfiber cloth to dry the tile to avoid water spots.
Maintaining a Steel Backsplash
Begin by washing the steel backsplash with a mixture of 1 part vinegar and 1 part water. This will remove excess grease and dirt. Make sure to rinse well with water. Next, take a stainless steel polish and apply in a circular motion with a soft cloth. You can find a good polish at your local hardware store. Never use glass cleaner on your stainless backsplash as this will cause streaking.
Maintaining a Marble Backsplash
It is important to use the right cleaner on your marble backsplash or else the stone can become discolored. First, wipe the backsplash with a damp cloth and then dry immediately to avoid water spots. Using 3 drops of liquid dish soap and 4 cups of water, wipe down the marble again and scrub any stains. Make sure to rinse and dry thoroughly.
Maintaining a Stone Backsplash
Wipe down the stone with a soft, damp cloth. Using a mixture of 4 cups of water with 5 drops of liquid dish soap, wipe down the stone liberally. Make sure to scrub any strains and soils. Rinse the stone with warm water and polish with a dry, clean cloth. This will restore your the shine and luster to your stone backsplash.
Maintaining a Glass Backsplash
Using a mixture of 1 part vinegar and 1 part water, wipe down the glass with a soft cloth and rinse well. You can use a clean cloth and glass cleaner to shine the backsplash. For tough soils, you can use a small brush to spot treat any areas.
It is important to clean your backsplash regularly to avoid mold and mildew build up. Also, consider using a grout a sealer to enhance the life of the grout around your backsplash. Take a small brush and clean crevices with appropriate solution on a regular basis.
