Login Error
Close
5 Bathroom Sink Design Choices
by DoItYourself Staff
Bathroom sink design can be overwhelming. Not only do you want a sink that is functional, but you want something that will match the look and feel of the bathroom. There are so many style choices out there that it can become confusing. Here is a brief overview of the most popular sink designs, and the benefits each one will offer.
Standard Vanity Bowls
Many people will stick with the standard vanity counter with a sink bowl. This design has worked for decades, and with so many choices in material, color, and size, it will remain popular for the standard bathroom. A vanity can be customized in size, shape, and dimension.
Wall Hung Sinks
This isn't a widely used option, but can be great for children's bathrooms, those who need a lower sink, or just small bathrooms where space is not available. These are installed directly on the wall with no counter. The plumbing is hidden behind the sink. The challenge with these is the wall must be strong enough to hold the weight of the sink and the water. Many contractors won't install these unless the wall is a solid structural wall.
Pedestal Sinks
A pedestal sink is a great choice for guest baths and half or quarter bathrooms. There is no cabinetry involved. The sink bowl is on top of a stand, and is a solid piece. The pipes can be hidden in the pedestal portion of the sink itself. Installation of a pedestal sink is relatively simple, and can be done by anyone with basic plumbing knowledge. These sinks are popular for rooms that are smaller, and for bathrooms used by children.
Vessel Sinks
Vessel sinks are popular in homes with a more modern look. They require more space for installation, and the installation process is different. The faucets for these sinks are attached either to the back of the counter the bowl sits on, or directly on the wall behind the sink. With a vessel sink you can choose to have a bowl that sits on a counter, or a bowl that is partially submerged in the counter. Vessel sinks can also be created from virtually any material, and if you have a bowl that is large enough it can be used instead of a standard sink bowl.
Double Sink Vanities
For those with the luxury of a larger bathroom, a double sink can add a wonderful design element to any bathroom. You can choose a single vanity counter with two sinks, or two individual counters for the sinks. These are seen most often in master suite bathrooms, and serve as a 'his' and 'hers' sink.
Sink Materials
Regardless of the style of sink chosen a variety of materials will be available. Porcelain remains a popular choice. It's easy to care for and can be incorporated into any design scheme. Fiberglass-reinforced plastic is popular in homes where a sink needs to be molded in to an add shape. The downside is the finish doesn't tend to last long and it isn't as durable as other materials. Other materials such as stainless steel, china, and stone will also be options to consider.
 forum activity
