5 Benefits of Building a Floating Deck
A floating deck is a deck which is a temporary structure like a house or a wall. There are a number of benefits as to why people should be encouraged to build this floating deck, rather than building a standard anchored one. Some of the benefits are discussed below.
1 - Floating Deck Can Be Transported
A floating deck can be moved anywhere to any place at any time. The deck can be shifted from one place to another as it is not a permanent structure.
2 - Unsafe or Safe?
Many people feel that the deck would be unsafe without the anchoring wall. However, in the case of floating decks, the deck would be as safe as any other deck with or without an anchoring wall.
3 - Concrete Blocks
The floating deck is mainly built of concrete blocks rather than a layer of foundation of concrete. This helps in increasing the degree of comfort to the deck that will not move on the foundations.
4 - Long Lasting
If the deck boards are attached in the right and a proper manner to the framework, the floating deck would long last for a number of many years. However, good maintenance needs to be provided, as well as a coating on the floating deck at regular intervals.
5 - Increase Space
Building a floating deck might just increase the available living space of your house as it would include some outdoor space also.
