Login Error
Close
5 Benefits of Having Water Cisterns
by DoItYourself Staff
Installing water cisterns can provide home owners with a number of unique benefits. It presents a legitimate alternative to other water systems that are currently used. Here are some of the benefits of having water cisterns.
1. Environmentally Friendly
One of the great things about a water cistern is that it is environmentally friendly. When you set up a water cistern, it will collect rainwater for you. This will provide you with a source of water that many people allow to go untapped. The vast majority of the world simply gets their water out of a well. There is only so much water in the ground and it takes a long time for the water to make its way back down to that depth. Therefore, capturing the water as it is released from the clouds can present you with a great way to help the environment.
2. Save Money
When your water system is attached to a water cistern, you can also save quite a bit of money. Consider how much money you spend every single month on your water bill. A cistern will allow you to have water available to you at all times for free. You pay for the cost of the water cistern and the installation. Then, you do not have to worry about a water bill ever again. This allows you to get your water without paying a dime after the initial cost.
3. Independence
Water cisterns also provide you with a way to be self-reliant. You do not have to worry about hooking up to a city water source. Therefore, you know that as long as it keeps raining, you will always have water to drink. This will be true regardless of what happens to the city in which you live. With so much uncertainty in the world, it is great to know that you do not have to rely on anyone else for one of life's most important necessities of life.
4. Safe to Drink
Although the thought of drinking rainwater does not sound very appealing at first, in reality, using a water cistern is very safe. All of the new water cistern systems have a purification system that allows the water to be safe to drink. It will either use chlorine or ultraviolet light to sanitize the water. This will effectively kill any germs or bacteria that are living in the water.
5. Unobtrusive
Many people think that a water cistern is going to be too large and take up too much space around their house. However, with modern water cisterns, you usually will not even see them once they are installed. Many times, they will put them up on the roof of the house out of sight. Then it is free to collect rainwater, purify it, and send it down to your house without any input from you.
 forum activity
