Login Error
Close
5 Benefits to Self-Rimming Sinks
by DoItYourself Staff
If you need to install a new sink in your kitchen, you might want to consider one of the many types of self-rimming sinks that are available. Self-rimming sinks have rounded corners and are mounted on the top of a countertop. There are several advantages to this type of installation, and this article will provide you with a few reasons why they are an excellent choice for your kitchen.
1 - Easiest Type of Sink to Install
Self-rimming sinks are by far the easiest type of kitchen sink to install on a countertop. In fact, in most cases, you only need some plumber's putty for the drains and seals on the pipes and won't even need to use sink clips. You can use some putty along the edges of the self-rimming sink to make the installation more permanent. However, even this is not required. Simply put, you simply need to drop a self-rimming sink into place and then connect the plumbing. After that's done, nothing else is usually required before you can start using the new sink.
Installing the sink yourself is a great DIY project that allows you to save money while learning a skill that will help you feel more confident when doing other repair and maintenance chores around the home.
2 - Simple Design Means Fewer Leaks
The simple design of most self-rimming sinks means that are there are usually fewer problems with leaks. Because self-rimming sinks are usually made from one piece molded designs, there are few, if any, seams where a weak weld or joint will result in a water leak. So, if you are looking for a type of sink that is almost guaranteed to never leak, a self-rimming design may be something you should consider.
3 - Easy to Replace
Just as they are the easiest type of kitchen sink to install, self-rimming sinks are also the easiest to replace. Replacing a self-rimming sink is as simple as disconnecting the plumbing, lifting the old sink out of the countertop and reinstalling a new one. In fact, you can replace a self-rimming kitchen sink in half an hour or less in most cases.
4 - Matches Almost Any Countertop
Because of the way they are made to easily fit into the top of a countertop, they also an excellent choice for mixing and matching with countertop materials, backsplash types and other areas of your kitchen. In fact, you will be able to find a self-rimming kitchen sink that will match any countertop, kitchen backsplash or other part of your kitchen. Most self-rimming sinks are made of stainless steel which looks good in any kitchen.
5 - Less Expensive
Last, but certainly not least, in the list of benefits of a self-rimming sink is the fact that they are much less expensive than other types of sinks. Self-rimming sinks are often produced using steel injections methods that allow the sinks to be produced efficiently, which means they are simply easier to make than some other types of sinks. The popularity of the sink type also means that manufacturers are often more competitive with their pricing of these units. The competition between sink makers means lower pricing for you.
 forum activity
