Login Error
Close
5 Best Air Purifier Placement Techniques
by DoItYourself Staff
For the best air purifier placement take into account the area you are working with, and which rooms will profit most from having an air purifier. The number one place to put an air purifier is in a baby's room, but there are other places you could strategically place an air purifier to get cleaner air.
#1: Whole House Placement
The best air purifier is large enough to handle the whole house. Place it near the intake for the air conditioning unit so that there is a continuous flow of air, and much of the air will get circulated throughout the home. Be sure to keep your AC unit and filters clean, or filtering the room air will not have much effect. In winter, places the air purifier as centrally as possible, but avoid placing it near the intake grill of a furnace.
#2: In the Corner
Placing an air purifier in an out of the way corner will allow it to trap airborne particles, keeping the room air fresh and clean. Being in the corner reduces the trip hazard, where placing it in the center of the room might work faster, but be far more dangerous.
#3: Behind the Sofa
Most air purifiers act as smoke eaters. Placing one behind the sofa where smokers sit will remove smoke from the air and reduce the odors associated with smoking. For best results, place the air purifier near the ashtrays that get used the most often, speeding up the filtering process.
#4: Near the Door
A UV air purifier near the door can act as a sort of shield, filtering out bacteria and other microorganisms as they enter the room. This  will help reduce possible irritants throughout the home, and could be very helpful those who suffer from asthma.
#5: In the Kitchen
In the kitchen use both a UV lamp and a HEPA filter. Place the unit near the stove, or a few feet away from the trash can. The two rooms of your home which generate the most odors and host more forms of bacteria are the kitchen and the bathroom. Because of the suitability for bacterial growth, having a UV air purifier is almost a necessity, and theHEPA combination will remove all those dead microbes from the air so that you are only breathing clean, fresh air.
General Tips
Place the air purifier so that it is near the worsts sources of odors. If you have a baby or small child in the home, a small UV air purifier in the child's room will help him or her sleep more safely. In general, try to keep the air purifier in an area that gets a good amount of air flow, so that it is able to filter as much debris out of the air as possible.
Cleaning
Once you have an air purifier installed, keep in mind that the filters need to be cleaned regularly. Some air purifiers have a light that indicates a dirty filter, but others need regular maintenance to check the filter condition.
 forum activity
