5 Best Uses for Flooring Staples
Flooring staples are floor fasteners that can be easily installed using flooring staplers. Unlike nails, flooring staples provide more stable fastening because these materials attach the flooring materials to the floor at two different points at once. In addition, it is easier to fasten because it only requires one push on the stapler. Here are some of the best uses for flooring staplers.
1. Fastening Hardwood Flooring
Hardwood flooring can either be nailed or stapled on the floor depending on its thickness. However, if the floor is made out of concrete, it requires the installation of plywood or OSB first before the installation of the hardwood flooring materials because flooring staples cannot attach themselves directly to concrete. Hardwood floors come in two types: hard hardwood flooring and soft hardwood flooring. Before deciding to use staples, make sure that the hardwood material can be penetrated by the staples first. This will depend on the thickness of the material as well as it hardness or softness.
2. Fastening Vinyl Flooring
Vinyl sheets can be fastened to the floor more efficiently with the use of flooring staples. When vinyl sheets are glued to the floor, the adhesive may later on become loose due to moisture and other factors. However, when these sheets are fastened further using staples, they remain in tact even if the adhesive becomes loose. In addition, vinyl sheets are relatively thin and can therefore be stapled as a subfloor with ease.
3. Installing Laminate Flooring
Laminate flooring is easier to install than hardwood and can be stapled a lot easier to the floor. Laminate flooring is made out of synthetic multi-layer flooring product and uses melamine resin as a key component. Since this type of flooring is softer than hardwood flooring products, it is a good candidate for stapling.
4. Fastening OSB and Plywood
OSB and plywood are two of the most common materials that are laid on the floor before other subfloors. OSB is made out of soft hardwood that has been bonded together using resin. OSB and plywood are comparatively softer than hardwood and are therefore a lot easier to staple. After the installation of either OSB or plywood, the surface can be topped with other types of flooring materials such as hardwood, laminate or vinyl flooring. OSB and plywood can also stand alone without any other type of flooring stapled on top of them. In addition, OSB can also be stapled to the surfaces of wooden furniture such as tables and benches.
5. Fastening Carpets and Rugs
Flooring staplers also provide good use when fastening carpets and rugs on the floor. Some homeowners find it best to staple these flooring materials and therefore decide to staple them for better stability. Carpets can also be stapled on other wooden flooring surfaces such as the stairs. When stairs are to be carpeted, the best option is to staple them and not glue them to the floor since glue may destroy the surface of the wooden material underneath the carpet.
