5 Best Uses for Foam Adhesive
Foam adhesive is a powerful polyurethane-based adhesive useful for many applications. It provides resilient and permanent bonding to various materials. This spares you from having to do various jobs more frequently. Wherever the adhesive is used, bonded items will keep in place much longer. The adhesive is also more economical and faster to use than other construction adhesives. Below are 5 uses for the adhesive.
Cuts, Rips, Tears
If there’s one thing you can count on in the home, it is wear and tear of household items. Trying to get an item back in good shape can be a challenge with conventional adhesives. Use foam adhesive to effectively mend cuts and tears in household materials. It also works well for minor automobile repairs. The adhesive can be used on various materials such as wood, plastic, cork, rubber, metal and cardboard.
Construction
Foam adhesives are very useful for construction. They can be used to secure quick bonding of building materials. Plywood, foam board, dry wall and other building panels can all be securely attached with the adhesive. It can also bond rigid foam boards to masonry walls.
Foam adhesive is a fast and permanent solution to all sorts of wall bonding. Simply apply some adhesive to the particular surface using a calk gun. The adhesive is highly effective so you needn’t dispense as much as you would if using conventional adhesives. Press the board to be attached onto the wall firmly in place. Release the board after a few seconds. It’ll have developed adequate tack to keep it securely in place.
Floors
You can attach sub-floors to floor joists much faster with foam type adhesives. It provides a stronger bond than other construction adhesives. The product adheres to frozen or wet lumber just as well as it does on dry wood. Use a caulking gun to dispense the adhesive onto the sub-floor. Work from top to bottom and apply about 3 inches apart. You then place the desirable floor panels into place and allow time to set. The adhesive can also be used to install a range of floor tiles.
Sealing Leaks
Air leaks in the home add significantly to the energy costs of many homes. Air infiltration and heat loss adds more pressure on home heating and cooling systems, causing them to operate for longer. This necessitates increased utilization of electricity, natural gas or other fuels used in household heating and cooling. In most homes, the heating and cooling accounts for about 50 percent of energy costs. Sealing air leaks can improve insulation and energy efficiency.
Reinforcing Against Hurricanes
Hurricanes cause much damage to homes in hurricane prone areas. Safeguarding your property from the vagaries of nature is a wise measure. Foam adhesives can be used to install hurricane shutters and other protective barriers more securely in place. When well fortified, hurricanes and other destructive weather wreak less havoc on your family’s lives and property.
