Login Error
Close
5 Brick Fireplace Surrounds Design Tips
by DoItYourself Staff
Homeowners planning to make their brick fireplaces aesthetically appealing should consider various designs for decorating the brick fireplace surrounds. Fireplaces are among the most conventional of internal heating systems and their appearance can be very predictable. Brick fireplace surrounds add a sense of style to the overall appearance of the fireplace but most surround designs have become quite regular. To make your brick fireplace surrounds unique, consider some contemporary design options.
1. Using Vibrant, Unconventional Surrounds
Rather than installing a conventional-looking wooden fireplace surround, you can create a personalized design by using vertical or horizontal wooden planks and strips of varying shapes and colors. The standard wooden surrounds render an enclosed, cabinet-like appearance whereas the use of planks installed around the fireplace uses less space and gives room for greater customization.
You can use strips of different color shades and textures and alternate these strips with the bigger panels. This creates a more vibrant look than conservative, carved wooden surrounds. Wooden strips created from hardwoods are best suited for this purpose due to their proven durability. These can be easily stained in a shade of your preference.
2. Using Steel Surrounds in Different Ways
Stainless-steel fireplace surrounds are among the latest offerings in this niche. These are recommended if you prefer a formal, defined appearance for your brick fireplace. If the lighting around the fireplace is directed towards the steel surface, it is bound to sparkle a bit, easily making the fireplace, the focal point of the room. However, such stainless steel surrounds too seem to have become quite commonplace. You can embellish them a bit to tone down their formal appearance.
For instance, using a power sander, you can sand along defined sections of the steel surface. If you choose do this in the form of alternate squares, you will have a steel surround surface with alternating, smooth (shiny) and slightly-rough textured surfaces. Most steel fireplace surrounds are retailed in the form of sheets that can be easily screwed onto the wall. Instead of creating a seamless surround, insist upon inducing visible seams between the horizontal and vertical surround panels. These seams can be later colored with a shade that complements the surrounding walls in the room.
3. Consider Brick Surrounds with Faux Finishing
One of the most economical choices in this niche is to use faux finishing. Faux finishing is the easiest way of updating the dull appearance of a typical, brick surround. You can use faux finishing of various types. The most preferred options in this niche include slate or wood finish. These finishes complement the brick surface, exuding an equally natural and rustic appeal.
4. Create Natural Stone Appeal by Using Rox Panels
Rox panels are a recommended choice for creating surrounds that exude the aura of natural stones. Rox panels are actually a cheaper alternative to renovating the entire surrounds with natural stones. Rox panels are essentially thin sections of natural stone like slate that are installed over an existing surface like a brick surround surface. Most folks prefer to use Rox panels of varying thickness to establish a more natural appeal.
5. Embellish Basic Brick Surrounds with Tiles
A more economical option over using Rox tiles is decorating a basic, brick surround with decorative tiles. This is recommended particularly for brick surfaces since tiles can be installed over them as a part of DIY projects. You can create various patterns using the tiles, including chequered patterns or use tiles of a color that complements the mantel or the surrounding walls.
 forum activity
