5 Common Problems when Wiring a 3 Way Dimmer Switch
When you decide that you want to put your lights on a dimmer switch, you can complete the job in no time. With a few tools and your handy wiring diagram, you can add a custom lighting solution to any room in your house.
Most dimmer switches are set on a 3-way switch. This means that the lights can be turned on and off from the dimmer switch as well as another light switch. 3-way switches are common in hallways and staircases. They are often found in large rooms as well. If you avoid the five problems below you will wire your 3-way dimmer switch just like a pro.
Common Problem 1--Buying the Wrong Size Switch
You should calculate the maximum fixture wattage before you buy your dimmer switch. The maximum wattage should be clearly marked on the fixture. You may have to take the bulb out to read it, however. Once you have located the maximum fixture wattage for each individual lamp, you will need to add them up. That number will help you determine the perfect size of the switch you need to purchase.
For example, if you have want to connect the dimmer switch to four recessed lights with a maximum wattage of 75, you will multiply 75 by 4. The total maximum wattage for those fixtures is 300. That means that your new dimmer switch will have to be able to handle a load of 300 watts.
Make sure that you check the fixture for the wattage and not the light bulb currently installed. This method can yield a total too high or too low.
Common Problem 2—Failing to Locate the Common Wire
When wiring the new switch, you will need to find the common wire. The common wire will be on an easily identifiable screw. You will need to connect this same wire to common screw on the new dimmer switch. If you don’t locate the wire and connect it properly, the lights will not work from more than one switch.
Common Problem 3—Failing to Ground the Switch
You will need to locate the ground wire and connect that to the switch as well. The ground wire is what prevents stray current from electrocuting your family and possessions. The ground wire is often white, green, or bare.
Common Problem 4—Using Improper Bulbs
Unless otherwise noted on the packaging, dimmer switches should not be used with fluorescent or energy saving light bulbs. They are designed to work with incandescent bulbs.
Common Problem 5—Not Checking Both Switches
Before you put up your tools and tidy the work area, you need to make sure that the lights work from both light switches. If you fail to check both switches, you may find that one of the switches doesn’t work. If that is the case, you will have to pull your tools out and remove the switch to determine the problem. If you check both switch plates right away, you will know if you have to do any troubleshooting.
