5 Creative Barbeque Ideas
If you feel you always grill the same old burgers and hot dogs, consider these creative barbeque ideas.
Grilled Skirt Steak
Skirt steak is a cheaper and thinner cut of meat than steak, but it cooks quickly and really retains flavor. The best thing to do with skirt steak is to season it with spices or use wood chips to give it a pungent aroma.
Seasoning is an important part of any barbeque ideas you invent. If you want a spicy steak, marinate it in cumin, garlic, pepper, chilli powder and oil in the fridge overnight. Try adding Chinese five-spice for an extra kick. When you are ready to cook, let the marinated steak sit on the side for an hour or so before you place it on a grill. The skirt steak will require about three minutes each side, but watch it closely, as it is a very thin cut of meat.
Moroccan Chicken
You can cook a bit of poultry with Moroccan flavors. Try spicing this up even further with quail or pullet. You can Moroccan spice mixes, or you can make your own with the following:
- Cinnamon
- Cumin
- Coriander
- Cloves
- Paprika
- Ginger
- Pepper
- Cayenne pepper
- Garlic, salt and lemon
Mix the spices together in a bowl. (Be careful not to overdo the paprika and cayenne; start with a little and add more if required.) Add olive oil and rub the chicken into the mixture. Marinate the chicken or poultry in a fridge for 2 hours. When ready, take out the chicken and place it on the grill. Be careful not to overcook the chicken, or it will become dry.
Jalapenos Wrapped in Bacon
Creative barbeque ideas also include appetizers or side dishes. Cut 10 jalapenos in half after removing the stems. Cut away the inside seeds and pulp. Mix together a combination of cream cheese, garlic powder and chives. (Add more herbs, if you like.) Stuff the prepared peppers. Wrap a slice of bacon around each jalapeno and grill them until the bacon is brown and crispy.
Cheesy Tomatoes
Not everything cooked on a grill needs to include meat. For some non-meat barbeque ideas, you might try halving large tomatoes. Stuff them with cheese and peppers, or anything else you fancy, before topping them with a layer of bread crumbs and cheese. Take the tomatoes outside, and grill them as you might a stuffed pepper, for 10 to 15 minutes, or until the skin is browned. For a twist, you can try adding wood chips to the bottom of the grill.
Pineapple Kebabs
Here is the sweetest of these barbeque ideas. Cut a pineapple into chunks and place them on a skewer. Add a mixture of butter and melted brown sugar; grill until the pineapple browns. Then coat the pineapple with chocolate sauce.
