Login Error
Close
5 Different Types of Light Switch Timers Explained
by DoItYourself Staff
Light switch timers are effective energy savers that will remind you to switch the lights off and will even give an impression that you are at home even if you are not with its automatic on and off lights. These timer switches are widely used in the industries, homes, and vehicles with its automated on and off options that will effectively protect you from possible burglars while lighting your home on the intended time.
Here we will discuss five different types of light switch timers that you can practically find anywhere. There are switch timers that can be synchronized with the real time, some have a command option to start timing, and some have combined uses for a higher level of time operation. Switch timers vary in size, in function, and design but the fact remains that it aims to make your life more comfortable and increase safety.
Type 1 - Plug-in Variety
This type of light switch timer is easy to install against your wall and allows operation of one light or appliance. To use this type, just position the tabs on the number dial according to how many times you want the lights or appliances to turn on and off.
Type 2 - Screw-in Timer
Screw-in light switch timers are enclosed directly into the light socket of the lamp which allows you to install the bulb straight into the timer.
Type 3 - Spring-wound
These types of timers have automatic dials that you can wind to power lights or appliances. Spring-wound timers have replaced the standard light switches and can be operated easily depending on your time preference. You can conveniently set lights to keep open for the duration of 1 to 60 minutes although that depends on your choice of where you will set the number dial to.
Type 4 - Electronic Auto-Off
These timers have the standard power on and power off button and have additional four buttons which corresponds to a precise time delay. Electronic auto-off timers are quite convenient and practical to operate with just a touch of any of the buttons. You may press 5 minutes, 15 minutes, 30 minutes, and 60 minutes by just pressing the buttons. If you want to add minutes on the time delay you may tap a single light switch paddle, each tap adds up minute.
Type 5 - Programmable Timer
Digital timers that contains a maximum of six daily on and off options and even a random setting which allows you to mix the times according to your desired number of times you want the lights to switch on and off even when you are not at home. Programmable timer is a more advanced light switch timer that will help foil burglars.
 forum activity
