5 Different Types of Line Conditioners Explained
If you have a HDTV, or a home theater audio visual system, then you will probably have several different types of line conditioners laying around the room. Line conditioners serve the purpose of dividing the alternating current, or AC, of your electricity supply unto more manageable units. The reason that HDTVs are considered to need these devices is that the power sent to the home is not 100% consistent, and this can cause problems in the quality of the sound or vision that your TV displays. In addition, storms and electrical surges can also cause problems with the supply, and rather than just turn off the HDTV during a storm, people prefer to adjust their line using one of these devices. The different types of line conditioner reflect the different types of electronic devices you might choose to use with them, and how often you will require the conditioner.
Uninterrupted Power Supply
Certain types of UPS are line conditioners. While most UPS devices only pass the power through to the device, the line conditioner UPS also serves as a surge protector. Examples of the UPS/line conditioner combination is the dual conversion online uninterrupted power supply, which keeps the power surges from affecting your network devices. Using a simple UPS when a conditioner would be required can leave the supply devices damaged, faulty, or even completely broken. It is therefore important to understand that not all of your UPS systems are line conditioners.
Low Impedance Isolation Transformer
These are best used in environments where there is a lot of pressure, and the survivability of the power line is vital. Low-impedance line conditioners have a complete isolation system, with grounding, to ensure complete surge protection, and a longevity which is connected to its tolerance for extremes of power variation. Variations of the impedance line conditioner include the medical grade specification, which is used for emergency hospital equipment such as heart monitors, life support machines, and other devices where the power is absolutely necessary, and literally a matter of life or death.
Voltage Regulation Precision Line Conditioner
These types of line conditioner offer a very reliable surge protector, which also ensures no break in the power path, which can sometimes affect machines. There is an automatic bypass system, so that any connected devices continue to be powered, even after the device itself has been damaged. The voltage regulation line conditioner is adaptable to be used in most situations, whether it is at home, or in the office.
Ferroresonant Voltage Line Conditioner
These line conditioners are used in high pressure situations, and can be used on dedicated lines and cables in order to ensure that the system performs to the best of its abilities. These are ideal for control units in factories, for emergency phone lines, and for generator power, where all of these absolutely need to retain power even in an emergency.
3-step Voltage Regulator
This is a much less high-pressure line conditioner, and is more suitable for the home and small business. This offers only line regulation and protection against surges, and it is intended to be used with items such as photocopiers and printers.
