5 Fire Sprinkler Jobs to Leave to Professionals
Fire sprinkler jobs are in demand as more and more buildings and homes require installation of fire protection systems. Each year, communities are requiring that fire sprinkler systems in various types of new construction are installed. Hence, this requirement created a demand for skilled installers to do the job. Some homeowners think that installation of fire sprinkler systems can be done by just anyone. But not all people are qualified to install and manage these systems. Here are fire sprinkler jobs that one should just leave to the professionals:
Job 1: Fire Sprinkler Installer
A fire sprinkler installer puts in and tests the fire sprinkler components, such as the sprinklers, piping, and valves. They are knowledgeable on local and national sprinkler codes. Fire sprinkler installation is a job that falls under the construction industry, which employs almost 7 million people. This job is a great opportunity to work in construction without having to be outside in the weather. This job allows you to work after the walls of the building or home is finished, so you can work in a controlled environment.
Job 2: Fire Sprinkler Inspector
The National Fire Protection Association, or NFPA, require the inspection, testing and maintenance of buildings with regards to water-based fire protection systems such as fire sprinklers. This is stated in the document NFPA 25. This paper concludes that control valves that don’t have electronic supervision should undergo checking on a weekly basis to ensure they are in an open position. Aside from the weekly check, the sprinkler system needs to be assessed four times a year. Other states may require more inspections, so it’s advisable to check local fire sprinkler codes. These are done by fire sprinkler inspectors. These inspectors are experts in NFPA requirements and they ensure that their system inspection complies with these guidelines.
Job 3: Fire Sprinkler Contractor
If ever there are changes in a building or structure, or whenever the building being used is changed, fire sprinkler systems need to be checked by a fire sprinkler contractor to determine if the system is still adequate. Changes in the water supply or changes to the sprinkler system equipment need to be assessed by a contractor as well. Basically, they are there to re-evaluate existing fire sprinkler systems when there’s a need. These professional are accredited to provide test certificates that are required when one is to comply with the insurance provider and local fire department inspection requirements. These contractors may also install fire sprinklers, design, fabricate, maintain and inspect the system.
Job 4: Fire Sprinkler Designer
A fire sprinkler designer is qualified and dedicated to do the layout and design of the fire sprinkler system that best meets your needs in compliance with NFPA requirements. They are knowledgeable in local and state building codes and insurance underwriter requirements; hence, their design should always comply with these codes and regulations.
Job 5: Fire Sprinkler Fitter
The fire sprinkler fitter is a professional installer of fire sprinkler systems. They are also very knowledgeable when it comes to fire sprinkler system safety regulation and codes. Therefore, their equipment complies with these safety codes.
