5 Gas Range Troubleshooting Tips
A gas range can be a desirable alternative to an electric range. This type of appliance allows the user finer control of heat, and it is considered to be stabler and more reliable than an electric model. However, you may find that maintaining you gas range can be a hassle. Before you call in a technician, try to diagnose the problem yourself by reading the following answers to common gas range problems.
Burner Not Lighting?
If your burner is not igniting, the cause is likely that your ignitor is weak or entirely burned out. You may need to replace the ignitor. The problem could also be with your gas supply: be sure to check it before you schedule an appointment with a technician or buy any new parts for your range.
Oven Won't Heat?
If your oven won't heat up, you should first make sure that there is no dirt or food particles blocking your pilot light. The pilot light is a small gas flame that lights your oven; if it becomes blocked, your burners will not light. If cleaning the pilot light does not help, there may be a problem with the gas supply to your range.
Alternatively, if your burners work but your oven won't heat, you may have your clock set for an automatic self-cleaning cycle. You may also have an issue with the thermostat, circuitry, or selector. If you suspect you may have a problem with one of these, call in a technician to check for you, as it is difficult to check for problems with them.
Oven Heats Incorrectly?
If your oven runs too hot or too cold, it's likely that your thermostat needs to be replaced or recalibrated. If your thermostat is mechanical, you can remove the thermostat knob and manually adjust it so that it more accurately reflects the oven's temperature. If you cannot adjust your thermostat, or you have an electric temperature-regulating device, you will need to replace the thermostat.
Oven Bakes Poorly?
If your oven heats, but food takes too long to cook or comes out soggy or scorched, your problem may be that your oven's gasket (flexible seal on the oven door) is defective. Frequently, if your oven bakes/broils poorly, it is because your gasket is defective or worn out. You can contact your manufacturer for a replacement, or visit a local hardware store. Poor baking may also be the result of a defective thermostat.
Smell Gas When Using Your Range?
If you notice a gassy smell or witness "mini-explosions" when you use your oven, your ignitor is probably aged, and your range may need to be replaced. Do not use a gas range that produces a noticeable gas smell or that produces small explosions.
If you smell gas even when your range is not in use, you should call your gas company and evacuate your home.
Of course, this is not an exhaustive list of all of the problems you can have with your gas range. The most important step you can take to help prevent and repair problems with your gas range is to be aware of its structure and the way it works. If you understand the way your range works, you will be better equipped to diagnose and address problems, even if addressing those problems means calling in a technician.
